servo motor
servo motor
having issues with the servo motor not cycling on power up. I only have 5 volts going to unit. Anybody have any suggestions on where to look where i may be losing voltage in the system?
Re: servo motor
try here maybe?? http://www.rz500.net/RZ%20500%20REFEREN ... TRICAL.pdf" onclick="window.open(this.href);return false;
start at pg 7-47
start at pg 7-47
Re: servo motor
thanks, I worked thru the wiring but can`t figure out why i`m losing voltage. Anybody know how to test the control unit
Re: servo motor
so i was sure the CDI was fried but found a wiring harness on ebay at a reasonable price.... thanks Colin, he was quite cheaper than the guy from Singapore asking $650. Swapped it out tonight, turned the key and the servo motor cycled. something in the harness was drawing too much juice
