500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Tue Sep 25, 2018 10:10 am
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Rzv fuel sender unit gauge
PostPosted: Wed Feb 26, 2014 8:06 pm
hey guys
just fixing my wavy fuel sender unit
i have a japanese rzv manual . and its in japanese . so i can understand the pictures and numbers :)
i cant see what way they recon to put in the fuel tank sender unit in
does it matter??
my bike was like this
my other bike was like this
i have not used the bottom bike enough to tell if the fuel sender is tell lies
anyone know ?
 Post subject: Re: Rzv fuel sender unit gauge
PostPosted: Thu Feb 27, 2014 5:59 pm
My RZV tank is like your top picture. I'm pretty sure it's never been removed. My fuel gauge is "wavy" too. What have you done to fix it
PostPosted: Thu Feb 27, 2014 9:22 pm
i thought top one was right .
on the bottom picture ,above my fingers the small box looking thing .
take that off and there is a small board with wire going across it . they have to be tight and evenly spaced .
all 3 of mine were out one of the boards was not stright and was bowed
. i just used a little needle pick and made them all stright and tested it and it seemed to have fixed it
take it apart and have a play around .you will see what i mean when you take the little cover off
good luck
PostPosted: Fri Feb 28, 2014 1:04 pm
Mines been like that for years, bouncing around!!! Horrible!!!
I've spent some time looking into this problem and the only reason I can see for this wavy operation is due to a capacitor located in the gauge circuit that acts like a damper, that's no longer working, most RZV fuel gauges are now bouncing around due to their age.
I've looked at the fuel float and it's a basic resistance voltage devider, all the gauge operation (and damping) seems to be done inside the gauge housing using electronc circuits.
All electrolytic caps degrade over time, so there's not much you can do to prevent this happening.
And because these fuel/temp gauges are sealed around the edges, most will stay that way.
Mine still works... just take the average of the bounce!!! :mrgreen: :mrgreen: :mrgreen:
Did the FJ have a fuel gauge??? :smt017
Andy (UK)
RZV500R
FRC
Faster Faster !!!
PostPosted: Fri Feb 28, 2014 4:58 pm
i think i may have a few temp fuel gauges . but who knows if they are any better . might just have to swap them and see
