Zeetronic problem, what is wrong ?
Ax-Racing
#1 Post by Ax-Racing » Mon Apr 07, 2014 3:14 am
Hello Guy
someone have installed a complete zeeltronic components ?
78mm rotor, two pick up
pdci-44v unit and rectifier ?
try to follw al manual instruction but bikes don't start
thinking to be wide out of correct timing
some adivce ?
Alex
megafer
Re: Zeetronic problem, what is wrong ?
#2 Post by megafer » Mon Apr 07, 2014 8:08 am
i had a similar problem and was a diode inside the zeeltronic. borut resolve the prolem and now works fine
megafer
#3 Post by megafer » Mon Apr 07, 2014 8:09 am
my system was not a compete one was a PCDI24V
Ax-Racing
#4 Post by Ax-Racing » Mon Apr 07, 2014 12:56 pm
borut answer me today
suggest to advance static angle and make a new test
finger crossed :-)
Alex
wolfgangh
#5 Post by wolfgangh » Mon Apr 07, 2014 4:06 pm
which static angle did you set? He recommends 35 - 40 deg ideally.
I have same setup then you but not ready to start.
You can generate test spark with this unit as far as I remember, did you get any sparks?
Ax-Racing
#6 Post by Ax-Racing » Mon Apr 07, 2014 4:42 pm
spark test is good
now i have to try two more options
first one, moe pick up to have more static angle (now i'm on 35°, but not sure that pick up work at beginning of mark ora half or at the end)
second, try to reduce gap between pick up and mark on flywheel
Alex
wolfgangh
#7 Post by wolfgangh » Mon Apr 07, 2014 5:03 pm
Pickup triggers ca. 1 mm after the magnet has passed the beginning (leading edge) of the pickup sensor. The gap should be below 1 mm ideally.
Ax-Racing
#8 Post by Ax-Racing » Tue Apr 08, 2014 10:35 am
someone suggest me to reduce gap between pick up and mark
now is 0.5mm,
Alex
Ax-Racing
#9 Post by Ax-Racing » Sat Apr 12, 2014 5:31 pm
Reduced gap pick/up - rotor
set cdi with more advance (don't understand why ?????)
but at last bike is running :grin:
Alex
