Coil body sparking
Coil body sparking
My restoration is finally nearing completion, bike starts and runs only on.three cylinders then intermittently on 4, would a bad earth cause the arcing on the lower coil body or has the units flux inside broken down? I dont have access to a multimeter tonight but will do when I.can scank one! Any.ideas guys?
- Rick Lance
- Contact:
Re: Coil body sparking
Check for a cracked or broken coil mount. Very common on the RZ5.
Hi.
Don't think it's the coil.
Each coil is for 2 cylinders.
Check the spark plug and carburation.
