500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Sun May 20, 2018 7:25 am
Post new topic Reply to topic  [ 5 posts ]
 Post subject: Tachometer erratic.
PostPosted: Sun Jun 08, 2014 5:41 pm
First issue with bike in long time. The tach all off a suddenearly in ride started reading 1,000 rpm low. It read 4,000 and I know at around 75 it should be 5,000. No issues with running the bike all day. Did around 160 miles with a bit of a hard run to miss rain on way back. When I put the blinker on the RPM goes up to what I think it should, and as the blinker cycles rpm varies by 1,000. Am taking bodywork off and double check wiring. Anyone else have this happen.
 Post subject: Re: Tachometer erratic.
PostPosted: Sun Jun 08, 2014 7:52 pm
bad earth somewhere
PostPosted: Sun Jun 08, 2014 9:37 pm
Your battery could be crapping out, try charging it. I've had the same thing and a full charge cured it.
PostPosted: Mon Jun 09, 2014 8:56 am
Thanks guys.
PostPosted: Fri Jun 13, 2014 11:36 pm
Now that you mention that Rick did the engine 3 years ago. Battery was put in at that time. will let you know when I pick bike up from suspension shop.
Users browsing this forum: No registered users and 4 guests
cron
