Tachometer erratic.
Posted: Sun Jun 08, 2014 5:41 pm
by pstamper
First issue with bike in long time. The tach all off a suddenearly in ride started reading 1,000 rpm low. It read 4,000 and I know at around 75 it should be 5,000. No issues with running the bike all day. Did around 160 miles with a bit of a hard run to miss rain on way back. When I put the blinker on the RPM goes up to what I think it should, and as the blinker cycles rpm varies by 1,000. Am taking bodywork off and double check wiring. Anyone else have this happen.
Re: Tachometer erratic.
Posted: Sun Jun 08, 2014 7:52 pm
by begbie
bad earth somewhere
Posted: Sun Jun 08, 2014 9:37 pm
by Mike Cichetti
Your battery could be crapping out, try charging it. I've had the same thing and a full charge cured it.
Posted: Mon Jun 09, 2014 8:56 am
by pstamper
Thanks guys.
Posted: Fri Jun 13, 2014 11:36 pm
by pstamper
Now that you mention that Rick did the engine 3 years ago. Battery was put in at that time. will let you know when I pick bike up from suspension shop.
