Witch replacement coil ?
RCEE
#1 Post by RCEE » Wed Jul 16, 2014 2:28 pm
Hi,
I'm looking for a replacement coil...i read a Suzuki bandit coil is the best option.
....but there seems to be many dufferent type of bandit coils available.
Witch one i have to look for that comes closest to the stock specs?
Cheers,
Rob
RD500LC Black/Red
FZ400R
Location Netherlands
2smoke
Re: Witch replacement coil ?
#2 Post by 2smoke » Wed Jul 16, 2014 4:05 pm
No.
Best coil is RZ350 YPVS 1986 and newer. Identical to RZ500 other than length of wire.
#3 Post by silverstrom » Wed Jul 16, 2014 4:58 pm
Or the Dynatek http://www.economycycle.com/servlet/the ... sh-/Detail" onclick="window.open(this.href);return false;
Vin
#4 Post by Vin » Wed Jul 16, 2014 6:55 pm
silverstrom wrote:Or the Dynatek http://www.economycycle.com/servlet/the ... sh-/Detail" onclick="window.open(this.href);return false;
anyone running the Dynatek coils?
any good?
#5 Post by silverstrom » Wed Jul 16, 2014 9:27 pm
Plenty of 350 guys running them with no issues. Hotter spark so perfect for highly tuned motors.
Like Colin, I prefer the stock coils as they are well known to be problem free. Same coil on the 86+ 350, the 500, TZR, TDR, and others.
I should have a spare stock coil here. If the OP is interested he can PM me.
RCEE
#6 Post by RCEE » Tue Jul 22, 2014 5:15 pm
I figured some data, of the coils:
The STOCK RD/RZ500 coil :
A RD350F2 coil;
The resistance values of those differ so much....i doubt that will work proparly ?
RD500LC Black/Red
FZ400R
#7 Post by silverstrom » Tue Jul 22, 2014 5:37 pm
2 things to consider. First, you've quoted F1 coil values, not F2 coil values.
F2 coil is primary .33 ohms +/- 15 %
Secondary is 5.9k ohms +/- 15 %
Secondly,
.67 -20% = .53 ohms and .33 + 15% =.38 ohms, so not so far apart.
12k ohms - 20% = 9.6k ohms and 5.9k ohms + 15 %= 6.8k ohms, so not so far apart
Regardless of those numbers I'm certain there is really no difference in the coils. One says 1UA on the tag and the other says 47X on the tag. That's if they have tags. Most don't and are used interchangeably on purpose and by accident with no ill effects.
RCEE
#8 Post by RCEE » Wed Jul 23, 2014 4:00 am
Thanks for clearify, my bad......im obsessed[like many others] with the ignition of the RD500.
I see even new coils still available in ebay
http://www.ebay.com/itm/Yamaha-RD500-Ig ... 7b&vxp=mtr" onclick="window.open(this.href);return false;
RD500LC Black/Red
FZ400R
#9 Post by silverstrom » Wed Jul 23, 2014 3:21 pm
That is expensive. A used one would be just fine and a lot cheaper.
