have spark,but no smoke at the right side
sinbadaszy
#1 Post by sinbadaszy » Wed Jan 28, 2015 8:12 am
hello my friends,here comes the problem,the bike run well before,one day i find it nok,the left 2 pipe smoke well,but the right have no smoke,checked the sparker all have spark,oil flow is ok in the carb,replace cdi no help,check ignition coil no finding,so i'confused where is the problem,i need your suggestion,tks.
updated :today i checked the wire,all is ok,after i remove the exhauster,have gas jet out after ignition,so the problem should be mechanical side,so i will split it again after 1500km,thank you everybody
2016/9/22 updated:
root caused is : Balance shaft bearing worn,so can ignite,but not continual,for your reference.my friend
pstamper
Re: have spark,but no smoke at the right side
#2 Post by pstamper » Mon Feb 02, 2015 11:51 am
This on Kawasaki? Have not been on site for a while.
vma500
#3 Post by vma500 » Mon Feb 02, 2015 2:29 pm
does the exhaust (gas)warm up well ?
sinbadaszy
#4 Post by sinbadaszy » Wed Feb 11, 2015 8:33 pm
after i removed the exhauster,plenty oil,after i started there gas jet out ,with some mechanical noise,i plan to split the machine to check
