500 Two-Stroke Tech
500cc GP-Replica Tech Forums
Search  FAQ  Register Login
It is currently Sat Jul 21, 2018 12:50 am
Post new topic Reply to topic  [ 3 posts ]
 Post subject: HORN NOT WORKING
PostPosted: Fri Feb 13, 2015 11:12 pm
The horn does not work,not sure if it ever did! I tried a new one but still not working.If I run direct power to the horn it doesn't work either.The handlebar switch block is a brand new genuine one.I read somewhere about trouble after painting the handlebars and earthing is that correct?Before I start checking the loom etc has anyone got a tip on what the problem might be,cheers
 Post subject: Re: HORN NOT WORKING
PostPosted: Sat Feb 14, 2015 1:11 am
I've powder coated bars and the horn has always worked.
It can only be 1 of 3 things: the switch, the harness, or the horn. Did you hook the horn directly to the battery. If you do that it should work. If not, the horn is garbage. If you hook directly to the battery and it does work, the problem is your switch or your harness. Could be as simple as a bad spade connector/wire.
PostPosted: Sun Feb 15, 2015 10:15 am
Thanks for replying,turned out the original was knackered,I got a replacement and the small screw on the back needed adjusting to get it to work,all good now :grin:
