Zeeltronics set up
pstamper
Zeeltronics set up
#1 Post by pstamper » Sun Nov 15, 2015 11:38 am
PV controller stopped working again so I soldered all the connections again. This is the controller from my street bike that I have been using. I have a Zeeltronics and was interested on any hints on swapping out. Looks straight forward and I do have a spare plug from my bad controller. Thanks.
Jim Bain
Re: Zeeltronics set up
#2 Post by Jim Bain » Thu Nov 19, 2015 12:20 am
Have you looked into getting your box rebuilt? check out http://www.twostrokeracelab.com" onclick="window.open(this.href);return false; his Name is Nick he is in Greece, he rebuilds PV"s and sets them up with switches so you can set them to open at different RPM's, I had mine done and seems to work good.
Jim
pstamper
#3 Post by pstamper » Thu Nov 19, 2015 10:06 am
No I have not. I need a second one anyway for my street bike. This could be an option. I will look up the site. I clicked on your link and came up all Japanese. After soldering it is working again. Question is how long. I have another one but some of the diodes are burnt out. Thanks for the info.
#4 Post by silverstrom » Thu Nov 19, 2015 7:18 pm
Nick has modified controllers for me. I think it's the easiest solution for controlling powervalve open/close points. No need to modify wiring and no complicated programming. Move the DIP switches to select the RPM you want.
cainpole
#5 Post by cainpole » Thu Nov 19, 2015 10:17 pm
Silverstrom, can Nick repair broken PV controllers? I have one that does not work.
#6 Post by silverstrom » Fri Nov 20, 2015 12:31 am
cainpole wrote:Silverstrom, can Nick repair broken PV controllers? I have one that does not work.
Yes, he can. Go to his website and scroll down and you'll see YPVS Controller Repair-Service.
The previous website address was wrong. He changed it in April 2015. You'll find him here http://www.2t-racelab.com" onclick="window.open(this.href);return false;
pstamper
#7 Post by pstamper » Fri Nov 20, 2015 10:23 am
Thanks will do. I am sure I can do some research but mine is a 47X and what is the stock controller set at? Has anyone used the shift kill feature on the Zeeltronic?
#8 Post by silverstrom » Fri Nov 20, 2015 11:31 pm
pstamper wrote: what is the stock controller set at?
6150 RPM - 7950 RPM
pstamper
#9 Post by pstamper » Sat Nov 21, 2015 8:57 pm
Thanks. My solder repair has the old one working Pulled the Zeeltronic controller out and says RD500 on case. The programmer is VCDI. Does not have the 24 after it. Can not find a wiring diagram for the controller and I was wondering if the programmer will work. There are not enough wires on the RD500 controller. I think the broken ones are going in the mail. Thanks for the help.
pstamper
#10 Post by pstamper » Tue Nov 24, 2015 9:08 pm
Borut came through. have a wiring diagram for the older controller. I am sure the programmer should be good. he did not mention anything about it.
#11 Post by MK » Sat Nov 28, 2015 3:51 pm
If you manage to just hook up 12V to the controller with the handheld attached, it'll show you the signature of the box (i,e. PPV Version xyz or VCDI Version xyz)
#12 Post by MK » Sat Nov 28, 2015 3:57 pm
6150 RPM - 7950 RPM
Please note that this is the stock setting, but it's total crap.
Even stock RD500 benefit from a much later full opening like 9-10000 rpm.
I had 2 customer RD500 with pipes (DIY and JL) that had huge dips in their torque curves which were completely cured with the RD500_mod2 setting above (fully open > 10000 rpm).
pstamper
#13 Post by pstamper » Sun Nov 29, 2015 9:24 am
Thanks guys. Tonight the soldering fixed the controller but out again. Once again at a raining track. Makes for an interesting ride. Yesterday rain and 44 degrees
two-stroke-brit
#14 Post by two-stroke-brit » Sun Nov 29, 2015 2:05 pm
look at this DIY manual
http://www.rzrd500.com/500phpBB3/viewto ... =5&t=13739" onclick="window.open(this.href);return false;
pstamper
#15 Post by pstamper » Mon Nov 30, 2015 3:14 am
Thanks. Managed to shim controller in the back and worked all day. Should have video up Monday. Rain tires worked great.
