RZ500 vs RD500 vs RZV wiring harness
thumper580
Re: RZ500 vs RD500 vs RZV wiring harness
#16 Post by thumper580 » Mon Aug 21, 2017 6:45 pm
which of the three wires above need to wired together to keep the headlight on? thanks alot for your help.
phildu31
#17 Post by phildu31 » Mon Aug 21, 2017 6:54 pm
It is red/yellow, blue and blue/black
thumper580
#18 Post by thumper580 » Mon Aug 21, 2017 8:42 pm
The plan..
1. connect the brown, black and green/yellow wires to my right handlebar connection and the single red/white
2. wrap together the red/yellow, blue and blue/black to keep the lights on
3. run a single wire from the thermo unit up to the connector that feeds the temperature gauge.
Am I missing anything?? Thanks, Mark
phildu31
#19 Post by phildu31 » Mon Aug 21, 2017 10:08 pm
Yes you can, but for the 3rd point, I think it will be easier to wrap at the old 9 pin connector level the green wire that comes from meter assembly with the green/red wire that comes from thermo unit.
thumper580
#20 Post by thumper580 » Tue Aug 22, 2017 12:00 am
Good news....I connected the two R/G wires together at the nine pin connector....now 12v goes from the thermo unit plug straight up to the dashboard connector for the temperature gauge.
thumper580
#21 Post by thumper580 » Tue Aug 22, 2017 7:28 pm
I feel I got the rzv harness to work ok. Only issue now is there appears to no connector up near the head light for the flasher cancellation. I assume the rzv does have turn signals...... strange. The attached pic is from the old harness. Any ideas?? Thanks again.
phildu31
#22 Post by phildu31 » Tue Aug 22, 2017 8:00 pm
So it seems RZV doesn't have automatic flasher cancellation.
It is optionnal in RDs : in Germany this feature wasn't supplied.
In RD harness, the yellow/black wire from the flasher relay ( on harness side of the 9 pin connector ) can be connected with a separate connector either to a yellow/green wire ( if cancellation unit is present ) or either to a black wire ( Germany with no cancellation unit ).
I don't know if RZ and RZV harness have this separate connector or if they are hard-wired.
You should just check it and if there is a separate male connector on yellow/black wire in the harness : plug it in the corresponding black wire female connector.
Anyway, you'll have to manually cancel the flashers.
thumper580
#23 Post by thumper580 » Tue Aug 22, 2017 9:37 pm
Mine came out of Canada and obviously they came with the turn signal relay and cancellation modules.... Oh well...everything else works. Thanks alot for your assistance.
phildu31
#24 Post by phildu31 » Wed Aug 23, 2017 4:05 am
Happy to help
