loom query
loom query
I'm in the process of building a new loom. My original loom has been butchered on a few occasions (adding an alarm etc) Just wondering if the connections shown below are from the factory (I assume they are). Its where the live and earth splits into 3 when going to the instruments. There must be a better way of doing this?
(excuse the dirty fingers)
Re: loom query
I doubt this factory with all my years working at Yamaha motor never seen that. Factory would used bullet type connectors.
My opinion.
My opinion.
Re: loom query
that's what I thought but that section of the loom did not seem to have been disturbed before.
Re: loom query
Maybe...But I doubt very much that is factory here is what factory usually used...
- image.jpeg (207.58 KiB) Viewed 1701 times
Re: loom query
The twisted and soldered wire split-outs are typical factory. Obviously hidden when the loom is taped up and finished.
Corrosion can be an issue at these joins.
Re: loom query
Sorry misread your post those type of soldering inside the loom are factory but not outside the loom.
Re: loom query
Yes, that is factory. Apparently keeping it simple works best. Twist, twist, twist and solder. 30+ years and still secure and working well.
Re: loom query
When I'm replicating this part I think I might use bullets rather than solder. I read recently (in CMM) that automotive joints in a loom shouldn't be soldered as they are brittle and can crack. Although taking on board silvertsrom's point, they've lasted 30 years with no probs! I think its easier to make a good crimp joint than a good solder joint. I've seen double bullet sockets but I've never seen a triple bullet socket. Thanks for this Frenchship. Although the earth wire in my picture above splits into 4. Any other ideas on how to do this? I was also thinking maybe a few tube type crimp joints. That might look neater when wrapped in loom tape.
