rectifier heat
trix
rectifier heat
#1 Post by trix » Thu Sep 14, 2017 12:31 pm
Hi
I've positioned a lot of components under the tank as shown. Any potential issues with overheating? Esp the rectifier??
Re: rectifier heat
#2 Post by silverstrom » Thu Sep 14, 2017 9:14 pm
The regulator-rectifier sheds excess charge as heat. Just make sure it has a good mount to act as a heat sink.
kpke
Re: rectifier heat
#3 Post by kpke » Fri Sep 15, 2017 10:44 am
I have done the same thing. No problems have been encountered.
I would post photos or point you to my build thread, but photo bucket :smt013
You need a good ground from the rectifier base/mount to chassis. I had to run a separate ground wire due to powder coating the mounting plate I used.
trix
Re: rectifier heat
#4 Post by trix » Fri Sep 15, 2017 6:57 pm
Thanks for this guys. i did not realize that the body needed to be grounded. Making a new loom so might run a ground wire to it.
