Need electrical help...I'm dying here!!!
Posted: Fri Oct 13, 2017 3:03 pm
by thumper580
Bike was running great but needed to fix first gear in the transmission.
Pulled stator to get the transmission cassette out, replaced the gear cluster and installed new shift forks. put everything back together.
start the bike and the lower cylinders are running fine but the top cylinders are missing and farting and weak exhaust output.
new plugs....same
swapped coils....same
swapped orange and black wires from upper coil to lower coil and vice versa.....same
different plug wires on upper cylinder....same
Ohms on pick up leads checked out ok
Ohms on windings were alittle high, but barely
has a 4 degree key on the crank, switched it forwards and backwards.....same
tried a backup cdi.....same
I'm out of options and miserably frustrated....... Any magical suggestions???
Re: Need electrical help...I'm dying here!!!
Posted: Fri Oct 13, 2017 4:09 pm
by Rick Lance
Did you paint anything while the motor was out? You may have a bad ground. Try running a dedicated ground wire from the stator cover to the upper and lower coils.
Posted: Fri Oct 13, 2017 5:17 pm
by tacky1
How long was the bike sitting, I would clean the carbs out, They might be gummed up from sitting, The ethanol is awful if you leave the bike sitting any length of time with ethanol blocker in the gas..
Posted: Fri Oct 13, 2017 5:48 pm
by thumper580
tacky1 wrote:How long was the bike sitting, I would clean the carbs out, They might be gummed up from sitting, The ethanol is awful if you leave the bike sitting any length of time with ethanol blocker in the gas..
The bike was only down three days and ran perfect before pulling the transmission.
Posted: Fri Oct 13, 2017 6:19 pm
by Paulrs
As you pulled the transmission the clutch must have been off. Crazy question but have you double checked the cranks are in phase. The front crank has the rotor on it so would not be effected, not so with the rear crank and one gear tooth out could give the problems you describe.
If above OK try the carbs.
Regards
Posted: Fri Oct 13, 2017 7:38 pm
by thumper580
Paulrs wrote:As you pulled the transmission the clutch must have been off. Crazy question but have you double checked the cranks are in phase. The front crank has the rotor on it so would not be effected, not so with the rear crank and one gear tooth out could give the problems you describe.
Regards
To pull the trans cassette you only take off the two nylon gears and the kick start gear, so both cranks never get changed or touched... These are on the clutch side of the bike.
Posted: Sat Oct 14, 2017 6:20 pm
by thumper580
Problem solved.... With the clutch basket off one crank can turn freely.... and I moved mine, unknowingly. Why I decided to check it I'll never know, but it was off....set it back where it should have been and it fired on the second kick and sounds wonderful.....
Posted: Sat Oct 14, 2017 6:23 pm
by thumper580
Regards
You were right....I didn't realize it until I rechecked....I never would have believed it!!!
Posted: Sun Oct 15, 2017 3:50 am
by phildu31
So, you mean that you swapped plugs, coils, wires, CDI, ... without checking if you had sparks ?
Posted: Sun Oct 15, 2017 11:32 pm
by thumper580
No, I had spark...that's what was driving me crazy..... It missed badly, popped and weak exhaust pressure. The rear cylinders were firing when the pistons were NOT at TDC. The crank turned out of time when I had the clutch basket off...
Posted: Sun Oct 15, 2017 11:45 pm
by tacky1
thumper580 wrote:Paulrs wrote:As you pulled the transmission the clutch must have been off. Crazy question but have you double checked the cranks are in phase. The front crank has the rotor on it so would not be effected, not so with the rear crank and one gear tooth out could give the problems you describe.
Regards
You have to pull the clutch to get the gearbox out, The clutch main nut is on the end of the gearbox shaft, Are you sure the cranks are timed correctly
EDIT: Sorry, I see you fixed the prob
Posted: Mon Oct 16, 2017 4:07 am
by phildu31
thumper580 wrote:No, I had spark...that's what was driving me crazy..... It missed badly, popped and weak exhaust pressure. The rear cylinders were firing when the pistons were NOT at TDC. The crank turned out of time when I had the clutch basket off...
Yes, but you didn't say it and we thought that you hadn't sparks on them.
The only thing you said is that you swapped nearly everything in the rear cylinders ignition and, in fact, all that was useless cause ignition was good.
Never mind, you found it.
Posted: Mon Oct 16, 2017 3:25 pm
by MK
phildu31 wrote:So, you mean that you swapped plugs, coils, wires, CDI, ... without checking if you had sparks ?
Which is completely harmless as the RD500 always fires all four plugs at once. So swapping them all around will always work.
