zeeltronic
shergar
Re: zeeltronic
#31 Post by shergar » Wed Jan 24, 2018 7:44 pm
great thanks for that phil , ps
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
shergar
Re: zeeltronic
#32 Post by shergar » Thu Jan 25, 2018 11:36 am
shergar wrote:great thanks for that phil , ps
tacky (paul) tells me he only uses 2 choke pulls to start his bike using 28s , dose it matter which barrels (carbs) you use the chokes on ie can you chop and change from one top one bottom on both sides or either sides . i have asked paul but to date no reply , cheers pa
my bikes.
CBX 1000 , RD 500 .
tacky1
Re: zeeltronic
#33 Post by tacky1 » Thu Jan 25, 2018 8:02 pm
Hmm, I did reply P,, You can use any 2 cylinders, I used one on each side.
The RG500 only uses 2 chokes.
shergar
Re: zeeltronic
#34 Post by shergar » Fri Jan 26, 2018 8:01 am
tacky1 wrote:Hmm, I did reply P,, You can use any 2 cylinders, I used one on each side.
sorry paul i only see it now mate for some reason i missed it and i normally receive an alert , thanks for the info , ps
my bikes.
CBX 1000 , RD 500 .
shergar
Re: zeeltronic
#35 Post by shergar » Thu Mar 01, 2018 10:05 am
shergar wrote:
silverstrom wrote:The eBay plugs are the same as those on the CDI and PV controller you sold and are meant to save you the grief of removing them from your CDI and PV controller Paul. I've done business with that seller in the past and had no problems. Can't remember what I bought though. The plugs are something new from him and look to be 3D printed. A good solution for an old problem.
john im also fitting a translogic dash (TLS-MD3-12) are there fittings on the market as per the zeel to make this a plug and go or do i have to cut into the loom for this , again no fittings came with it ? ta ps
on the translogic dash i have a yellow wire on its own it is called a tacho/rpm ignition coil signal wire do i connect this wire to the green/black wire from the zeeltronic called the none original rev counter or dose the yellow wire connect to the ignition coil signal to the bike ?? this green/black wire was not to be included in the standard plug and go plugs . i could really do with some advice on this one lads , cheers ps
my bikes.
CBX 1000 , RD 500 .
