It is currently Sun Jul 15, 2018 4:40 pm
 Post subject: coil question
PostPosted: Thu May 03, 2018 4:49 am
I'm about to get my frame and some other parts powder coated. Does the part of the coil (the laminated core) that is fastened to the bracket need to have metal to metal contact with the bracket?
 Post subject: Re: coil question
PostPosted: Thu May 03, 2018 8:21 am
My guess is yes. On my coil on PC bracket I ran a separate ground wire to ground.
(8) RZ350's
2006 R1 LE #158
Gold Wing/Trailer
PostPosted: Thu May 03, 2018 8:45 am
Yes, that is an absolute necessity to have it connected to the ground.
PostPosted: Thu May 03, 2018 10:58 am
In a word No, Apart from the coils having their own positive and negative, electrical connectivity is maintained through the bolt thread and under side of bolt. Make sure your bolts are good clean metal and run a tap through the internal threads on the frame. I have seen bikes were the owner has scraped the frame of its newly applied paint and plating thinking that's what it needs too get a good earth !
