Help with cdi dignosis
Hi can anyone help me please!!!!!! My 500 lc misfires from 4 to 3 to 2 to 1 cylinders and the will not restart? write! just rebult motor after 10 years in my garage, I have been through the usual new plugs, caps, leads top coil genuine! i also renewed all carb jets kits and and set levels correctly.thinking cdi? anyone got any resistances for it off a good one or can any body recomend a aftermarket cdi any help would stop me pulling all my hiar out whats left cheers all.
Yeah replaced coils but sparks are still weak! Checked all resistances in the manual and all in spec! the bike starts cold but within a minute starts misfiring on random cylinders before cutting out and wont restart.just wondered if someone had one on the shelf that resistances can be read from any help would be great so i can order a new one agian any advise on a good aftermarket cdi would be brill!
You meet a lot of people on the way up! Dont F**K them cause you meet them on the way down
- aaronmvrider
Did you fit the issue? What was it?
I recommend the Zeel as well I have an install procedure if you get one.
ZEELTRONICS PCDI-24V CDI & YPVS CONTROLER
http://www.zeeltronic.com/page/pcdi-24v.php
Good product.
Hope you figured it out.
JT
Good product.
JT
http://www.rdsonly.com/
JT
1975 RD350B
1975 RD250B -rough
1985 RZ500 - flame bike
JT
1975 RD350B
1975 RD250B -rough
Magneto failure
Can anyone run up there rd500 for me for 5 mins and feel the flywheel cover to see how hot it is because my engine is warm but magneto cover is boiling? and then i loose spark and my battery fuse blows!! thinking my magneto is shorting out . Also where can i sorce one? any help would be most helpfull!!!
- Gary Papesh
It sounds like your stator has a short.
You may be able to have it repaired or replaced cheaper than a 1ge box.
I don't have any experience with this company, but it would appear they could help you. http://www.westcountrywindings.co.uk/applications.htm
Good luck!
Sincerely, Gary P.
Good luck!
Sincerely, Gary P.
