It is currently Fri Aug 17, 2018 7:04 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: Clevis Pin for Rear Fuel Tank Bracket
PostPosted: Sat Feb 03, 2018 2:40 pm
Can't find a Clevis Pin online for the rear fuel tank bracket.
Part number 91702-06075 PIN, clevis.
Can anyone post the measurements? I'd like to make one out of titanium.
I could make up my own dimensions, but I'd like to copy the OEM part.
Thanks! :smt006
 Post subject: Re: Clevis Pin for Rear Fuel Tank Bracket
PostPosted: Sat Feb 03, 2018 3:57 pm
The rear fuel tank pin is 75mm long(less the head) and 6mm dia
The hole for the r clip is 4mm from the end.
Image[/quote]
PostPosted: Sat Feb 03, 2018 5:45 pm
Thanks, Steve!
3/8 inch grade 5 titanium rod ordered.
Head width looks about 8.5mm.
PostPosted: Sun Feb 04, 2018 12:27 pm
Smoker wrote:
Thanks, Steve!
Just checked the head, 8mm
PostPosted: Sun Feb 04, 2018 2:58 pm
Thanks, again!
Posting dimensions of these NLA parts is helpful, as it's getting harder and harder to find good and reasonably priced used parts.
I'll post a pic when it's done.
PostPosted: Sat Mar 10, 2018 2:58 pm
Spent more time improving the design of the clevis pin.
Have the titanium bar ready to machine, and had a question.
Why is there a clevis pin, instead of a bolt and nut?
My guess is that a bolt and nut would "squeeze" the pivot, whereas the clevis pin would put no pressure.
So, now I'm wondering why I can't use a titanium bolt with a locknut, instead of a clevis pin?
Is there some other advantage to using a clevis pin?
PostPosted: Sat Mar 10, 2018 3:03 pm
its a convenience so when you remove the front nut and bolt you can pivot the tank back and hold it up with the strap to get at the top spark plugs etc...
PostPosted: Sat Mar 10, 2018 3:11 pm
Thanks, bolly.
I enjoy designing and fabricating titanium parts, but it's expensive. At the last minute, I'm thinking it's not necessary to have a clevis pin for this application. Also, a titanium bolt and nut will look better than a titanium clevis pin.
Any reason to NOT use a bolt and locknut?
PostPosted: Sat Mar 10, 2018 3:25 pm
No, there is no reason you can't use a nut a bolt. If you want to lift the tank, remove the nut and bolt. It will take a similar amount of time as removing the pin.
If I need to work under the tank, I remove the tank. I suspect many people do. I have no desire to watch my tank fall on me as I work with it held up by a cable, which itself can damage the tank. And remember that the fuel level in the tank must be low enough so it doesn't piss out the cap and the vent if you do pivot the tank.
PostPosted: Sun Mar 11, 2018 10:15 am
Ya, it's a pretty slick system! A real engineering marvel
Shake "N" Bake!
PostPosted: Sun Mar 11, 2018 1:56 pm
As usual, it takes me a long time to figure things out.
All along, I was thinking the purpose of the clevis pin is for quick removal of the pin, without tools. Probably for roadside service.
Realizing this isn't true is why I decided to change to a bolt and locknut
And it would probably have cost $100-$150 usd, just for the machining. Gun drilling a small hole through 3 inches of titanium isn't easy, for sure.
PostPosted: Sun Mar 11, 2018 5:25 pm
Why do you want it in titanium ?
And why not to make it in aluminium ?
PostPosted: Sun Mar 11, 2018 7:29 pm
I for one enjoy reading Smoker's fabrication. The exotic metal pictures are great. I do enjoy it. Keep it up Smoker
1991 3MATZR250SP
!993 3XVTZR250SP
1996 RGV250(Lucky Strike)
1994 MC28SP
1995 MC28SP
1996 MC28SP
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1985 NS400R
1985 NS400R
1997 VFR750
1992 FZR1000
RGV400
TZR500
TZR350
1990 RZ350
1971 Porsche911S
PostPosted: Sun Mar 11, 2018 11:42 pm
All hardware will be gold titanium nitride coated. Works best with polished stainless or titanium.
Almost all parts I make out of titanium (or buy) are to replace OEM steel parts. So, at least 40% weight reduction per part.
I've never seen any bike with all gold TiN hardware.
PostPosted: Mon Mar 12, 2018 6:17 am
Ok, that's a real deal.
Mind the galvanic corrosion with other parts in metal.
