It is currently Tue Nov 13, 2018 3:43 pm
Post new topic Reply to topic  [ 101 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: Need Help With Tank Calculation
PostPosted: Sun Sep 09, 2018 11:07 am
The backup plan will be to use the miscut pieces, and hand cut one larger piece to fill in the bottom section. Have plenty of leftover tubing. Would not be perfectly round, though.
PostPosted: Sun Sep 09, 2018 1:48 pm
That's what I meant to do with grinding.
There's not too much that needs to get off each mating surface to close the gap at the end.
PostPosted: Thu Sep 13, 2018 12:53 pm
A week ago, the laser company said they would discuss with the cutting technician and get back to me with details, so I know how much titanium to order.
Haven't heard one peep. :smt012
Just sent an email saying I would accept the refund. Can't keep waiting.
Will try to cut a larger piece by hand to finish the circle. If it's too far off, might need to trim down all the pieces.
PostPosted: Thu Sep 13, 2018 4:21 pm
So close, yet so far away. Stay positive Pete. You'll get this issue resolved.
It looks like you should be able to make the last piece knowing what the angles are and the measurements needed. Perhaps a template first to insure it's correct and then the actual piece. I can see a belt sander being useful in getting to the exact fitment.
PostPosted: Sun Sep 16, 2018 5:57 pm
Need to set it up again. Then measure short and long gaps at the center (for the bottom section).
Used to have a pipe program that would print out paper templates. Hope I can find it. Would be really great to have the template cut by a digital paper cutter. Not sure how accurate I can be by hand.
PostPosted: Mon Sep 17, 2018 2:09 pm
https://www.conelayout.com
And give it a try with hand cutting, except you're shakin like an 80yo ...
That's enough to check if it fits.
On the other hand: whats the sense of testing with paper if the 3D cutter cuts whatever they like ?
PostPosted: Mon Oct 08, 2018 12:05 pm
I don't have any software that'll make the template. So, I print out and cut 2 halves and tape them together. Hard to do with great accuracy. Almost there.
PostPosted: Tue Oct 09, 2018 11:38 am
Took me the better part of 2 days to figure out, make the template, and get a finished cut.
Thought a cutting blade on the angle grinder might bend the 1mm titanium. Took a while, but cut it with a dremel.
Finished it off with a HF belt sander.
Fit was near perfect.
Problem is, the new angle is too steep to mate with the previous angle.
Looks like I need to make 3 perfect pieces by hand, in order for it to work. :smt012
PostPosted: Tue Oct 09, 2018 2:30 pm
I think I'd grind a little off the pieces adjacent to the one with the filler hole. Change the angle a little to bring the opposite side closer together.
PostPosted: Fri Oct 12, 2018 12:33 pm
Usually I'd slightly hammer the edges to a correct shape before welding and even reposition the whole segment to the outer side.
Alternative/Additional option: Use a bit of filler rod.
In any case: After welding the visible "step" will be gone.
PostPosted: Sun Oct 14, 2018 8:26 am
Hammer? :shock:
Trying my best to make sure no hammering is needed.
