Hi.
School boy erro, but I took off all the fairing clips before getting them refurbished. Only I don’t now know which ones go where? Any one help? Especially the nose cone for the front fairing
Cheers.
Fairing Clips help
Fairing Clips help
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Yamaha RZ500
Ducati Panigale 959
Re: Fairing Clips help
Your photos are not showing in your post.
The upper fairing clips are very simple. There are 4 clips; 2 upper and one on each side. Place the clip so the nut is inside the box.
- jackson.40
silverstrom wrote:Your photos are not showing in your post.
There are six fairing clips in the nose cone (6mm thread)
Have a look at this photo,the left hand middle clip is missing but you can see where they fit
The top two clips that are facing out are for the headlight frame bolts to go into
Let me know if you need any more photo's
For the anoraks this clip is the holy grail of all clips
I did forget to mention the 2 up front. Thank you Steve.
Thanks guys.
If you have any pictures of the clips for the lower side panels and the belly pan, that would be helpful as well. Now that I have sorted out the sticking float valve on one carb and there is no more fuel pouring out the over flow pipe, I’m ready to put the fairing back on.
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Yamaha RZ500
Ducati Panigale 959
I’ve taken a few pictures below. Hopefully you can open them. I have 3 types of clips. Most of them are the same type (thinner ones). What are the two larger ones with the locating boss? I only have 2 of them. Then I have 3 larger clips, but think they are off the belly pan
https://www.dropbox.com/s/zk9gtg3bqtx4l ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/70uuvdg56o44o ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/m39t754143ztg ... .jpeg?dl=0" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Yamaha RZ500
Ducati Panigale 959
- jackson.40
I don't recognize the clips in the first photo
Second photo is clip part number 47X2173600, you should have seven (six for the nose cone and one for the o/s airbox for the side panel to fit to)
Item 8 here
http://www.rzv500r.net/Tech_docs/47X-PL ... age_64.jpg" onclick="window.open(this.href);return false;
item 38 here
http://www.rzv500r.net/Tech_docs/47X-PL ... ge_65.html" onclick="window.open(this.href);return false;
The last photo is clip part number 9018305024 and you should have thirteen of these
Item number 29 here
Item number 22 here
http://www.rzv500r.net/Tech_docs/47X-PL ... age_39.jpg" onclick="window.open(this.href);return false;
Clip part number 47X2836200 is item 30 here
http://www.rzv500r.net/Tech_docs/47X-PL ... age_65.jpg" onclick="window.open(this.href);return false;
Item 8 here
item 38 here
Item number 29 here
Item number 22 here
