Being a track bike I didn't need/want a key lock in the gas cap. It is a keyless screw in alloy cap.
As it was, the key that came with the bike only opened the gas cap - the bike had long ago lost its ignition key by the time I bought it
Different fuel tanks
Re: Different fuel tanks
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
What do you do for a front mount? The TZR tank mounts to 2 large locating dampers with a mount bolted to the frame and 2 large hooks under the tank.RC45 wrote:Nice to see my bike getting love when it was Marks bike
I currently have a TZR250 1KT tank on the bike.
Mounting is taken care of by welding a receiver similar to the TZR250 frame, so the tank hooks on and is fastened at the back.
Will post photos in a couple days.
The TZR tank looks very good on the RZ.
Yes, the tank and frame did need a little massaging.
I like the look the 1KT tank has. Fits the bike nicely as well.
The tank quick release
The tank clip receiver uses the same mount position as the regular RZ tank mounting system
The frame mod to accept the C-brackets under the 1KT tank.
The Tank brackets
Of course there is still the other option - just weld in a tank throat from another bike and bolt on a key-less tank cap I bought this RZV500 tank off another RZ500 Forum member with the fille cap already welded in.
The Tank brackets
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
I have 3 (1KT) tanks here and was considering using one on the RZ500 project bike. The info you've provided shows it is likely too much work for what I have in mind. I don't plan on using the stock airbox, so that may allow me to use a TZR front mount bracket to get around the problem, or perhaps fabricate something similar to get the same result. Whatever I do needs to be easily reversible. Love that modified 500 tank. That is a nice mod.
Yeah, the reason for the complex rear mount (the 1KT tank had to be trimmed) was so that I could switch between the RZV and 1KT tanks.
The smaller 1KT tank is the sprint tank and the bigger RZV can server as the enduro tank
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
