NEED A NEW RD/RZ 500 FUEL CAP ?
- jackson.40
Re: NEED A NEW RD/RZ 500 FUEL CAP ?
No problem,welcome to the group Mark
- Contact:
Hi, i tried to do the capswap with the ybr 125, thanks for the info for this i'd say first.
The prob is: I can't get the lock mechanism out of the original.
I came this far: At the inside i removed the washer, then the first rubber. But i see another rubber and no clip (like the ybr) to push in and get the lock mechanism out. What is the next step?
Thanks allready,
Richard
Thanks allready,
Richard
- jackson.40
Hi Richard
Some times there are two o rings to remove,i use a small screwdriver and care to take these out.You should then see the tab you need to push in,it will only push in with the key not in the lock.
Steve,
Merci beaucoup ( Thanks!!!)
Hej, I've just ordered a 125 YBR cap on Aliexpress, at 13$ .
Will let you know if it's worth it... if I ever receive it .
- jackson.40
Good luck!
Not bad at all !
I've received the Aliexpress YBR125 cap today.
Quality is okay. Let's even say pretty good.
Nothing to say about the assembly, the lock works well and smoothly. It fits the tank very well.
I assume the top surface may have marks quickly if I don't take care, but that's okay for the price.
That's what I expected, maybe slightly better.
For $ 13, I recommend .
The cap is a bit high when plugged in, but I think it was similar on the original one.
- jackson.40
Cheaper than this cap................
http://www.ebay.co.uk/itm/YAMAHA-FUEL-G ... SwHoFXrlw8" onclick="window.open(this.href);return false;
My keys don't have the 100£ plastic overmoulding additional feature !
Do you see the pictures of the cap in my post above? I'm wondering if I have issues with the sharing rights of this album.
- Rick Lance
- Contact:
Too bad it's highly radioactive as evidenced by the paint on the top of the tank being burned away just by being in close proximity of the new cap. Be sure to sit back in the saddle when you ride, my friend.
I guess there ain't no free lunch.
LOLRick Lance wrote:Too bad it's highly radioactive as evidenced by the paint on the top of the tank being burned away just by being in close proximity of the new cap. Be sure to sit back in the saddle when you ride, my friend.
- Rick Lance
- Contact:
A quick Google translate to Japanese for "Shiny New Fuel Cap" produced the clue.....
Fukushima
Fukushima
