It is currently Mon Aug 20, 2018 8:26 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: ex tz350-750-rgb500-rider
PostPosted: Thu Aug 02, 2018 5:58 am
Hi Steve, Zeel has an option to have cdi and pv controller in one
http://www.zeeltronic.com/page/pcdi-24v.php
You will need a handheld programer
http://www.zeeltronic.com/page/programmer.php
or what I prefer is the pc link cable for a laptop
www.vinsbuilds.proboards.com
PostPosted: Thu Aug 02, 2018 9:29 am
My controller was an older version with two separate black boxes. Borut was very helpful with wiring info and his site is good. I had issue getting tach to work. Finally went to one of the coil feeds an all good.
PostPosted: Thu Aug 02, 2018 9:40 am
howie43 wrote:
sorry not been on site much wife had a stroke ive been collecting parts to start build been looking at ax racing pics yzr replica fancy doing similar modifying top case to fitt carbs inline in v unshure wat carbs to use (any suggestions) thinking of making frame from scratch using aprilia factory swinging arm with different blocks on end when i can figure out machine also cnc clucht cover out billet for dry clucht make our own billet heads its going to take a month or so to get head round cnc to do these parts i will post pics when done and also intend making aviable to club our main problem is finding drawings or models for 3d if any one can help or advie with this side it be much appreciated
thanks for citation
in my italian forum you can see all machinigh on cases and building of new mainfold houses
hope it can helps
i will follow your progress
Alex
PostPosted: Fri Aug 03, 2018 1:38 am
thanks for reply's reference zee i purchased all in 1 cdi got it right
ax-seen your work excellent .i am struggling with making drawings on cad at moment learning do you have any drawings that i could use has a base drawing..in exchange im sure when cnc up and running we can do something for you hoping to cnc clutch cover dry clutch wit and with out kick start
king regards everyone steve
PostPosted: Thu Aug 09, 2018 2:04 pm
ign-carbs kienin air strike 38mm-brembo calipers arrived .waiting for ignition .need to sort reed blocks next possible v force any suggestions -cranks from america-dtr170 kit -suter clutch then ready to do engine build.done some research on frame possible going to build my own chassis using maxton shock and linkage by maxton-making former's for frame-i will be doing 2 off everything on this build so will be able to build 2nd chassis if anyone interested.after build std parts will be a viable /cranks cylinders heads covers generator .i have 16.5 wheels front rear 5 sets complete so when sorted above out first off on cnc set of triple clamps and will be able to start doing build/making chassis-rear blocks swinging arm.about 6wks off yet getting expensive and possible having to move machines to other location.if any one knows of units buildings a viable at reasonable rates for race shop in chester frodsham area that will take 3 machines 3phase lathe cnc miller 60t-press let me now
PostPosted: Thu Aug 09, 2018 2:07 pm
PostPosted: Thu Aug 09, 2018 2:52 pm
the transatlantic series was serious stuff
PostPosted: Fri Aug 10, 2018 5:34 am
the good days how its all changed
PostPosted: Fri Aug 10, 2018 5:35 am
:sad: :sad: the good days how its all changed
PostPosted: Sat Aug 11, 2018 6:50 am
Howie43,
for a non-native english speaker like me your posts are challenging. Can you try to build complete sentences with proper punctation? You may get more inputs then.
Wolfgang
PostPosted: Sat Aug 11, 2018 12:32 pm
sorry never been my strong point english i do suffer with spelling
Users browsing this forum: No registered users and 7 guests
