My project (1GE)
Speed Freak
Re: My project (1GE)
#106 Post by Speed Freak » Mon Jan 09, 2017 11:28 am
Possible that I also did them... I need to check :mrgreen:
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RC45
#107 Post by RC45 » Mon Jan 09, 2017 12:23 pm
It is possible I got a little carried away though...
CBR1000RR SP2 HRC WSBK
TZ500V/OW53 Track bike
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
TZR250 3MA Track Bike
427ci C5 Z07
Speed Freak
#108 Post by Speed Freak » Mon Jan 09, 2017 2:20 pm
But the nuts are not detailed... I`m missing the chamfer :smt018
Just a poor working view screenshot... No ejection pin spots.
:mrgreen:
Sometimes i thought that I`m going too much into detail...
But now I have seen that there is no thread on the grease nipple :shock: Shame on me!
Regarding crankcase - for the lower one I have the same problem as for the frame etc. regarding accuracy.
Upper case is in work, but i can`t work at home as my laptop isn`t good enough for opening the 3D scan (min. 8GB RAM).
As the workload in the company is going up after christmas holidays I guess there will not be much progress from now on.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#109 Post by Speed Freak » Sun Jan 15, 2017 8:37 am
Last project finished...
let`s move on to the next one :smt003
Bearings are already here, some other parts will be ordered next week.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#110 Post by Speed Freak » Tue Jan 24, 2017 3:29 pm
It`s getting expensive when the weather stays that cold... :smt005
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
RC45
#111 Post by RC45 » Tue Jan 24, 2017 3:54 pm
Very nice. Nice set of instruments there.
I would like to have some kind of accurate method for measuring hole center to center across multiple planes.
Such a bench jig would make capturing face planes of complex items much easier. At the moment I need to work from plane to plane, so any error is carried to the next plane.
Of course the projects we are undertaking are normally tackled by teams of people with 3D probes, so I suppose we are doing the best we can :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Speed Freak
#112 Post by Speed Freak » Thu Jan 26, 2017 6:53 pm
Yes, I have the same problem.
I`m doing all my work mainly with simple calipers...
On most of the parts I don`t need more accuracy as I don`t want to reproduce the parts.
If I want to do something like the rubber seals I take the parts again and measure them a bit more accurate and in the end it needs anyway 2-3 parts to try how it fits in reality.
On most parts the real dinesions can be found out by checking how the designer initially made the sketch.
Most of the RD500 might be drawn by hand or at least the designers learned how to draw it by hand.
A good designer is trying to use "full values", at least I`m trying to do it because I`m a bit old fashioned in this case :smt003
So if you do a sketch in CAD, try to rotate it around, think about how the designer made the dimensions on the drawing and in the end you will see, there is one option where every dimension is a perfect round value.
If you manage to do that you can also eliminate production tolerances which can be quite big as long as the designer considers them.
I have finally finished the air filter case today...
Can someone take me a picture and dimensions of the bolt and washer which is holding the wite bracket on the upper case?
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
#113 Post by Smoker » Fri Jan 27, 2017 5:29 am
These CAD images are great for those of us trying to learn about the RZ500.
I especially like the exploded views, so I can see how the parts are assembled.
Is there any chance you'll do a CAD RZ500 engine?
Speed Freak
#114 Post by Speed Freak » Fri Jan 27, 2017 6:14 am
I`m planning to do more or less all parts except the fairing.
Around 30% of all part numbers are already finished, mainly chassis parts and seals at the moment.
Hope I can speed up a bit now as a lot of the engine parts are quite simple (bushes, washers, many different bolts which are more or less copy&paste parts with different length...)
Crankshaft is waiting in my garage to be disassembled for measurement (tools for disassembling and pressing it back together is also in work), upper crankcase is in work.
As already mentioned my only problem is that I have no accurate measuring method at home for big things like frame and engine cases.
A 3D scan of the most complex parts would be nice but is a bit expensive for doing it "just for fun".
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#115 Post by Speed Freak » Fri Jan 27, 2017 4:04 pm
Temperature is still below -10°C... :smt011
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
RC45
#116 Post by RC45 » Fri Jan 27, 2017 4:29 pm
LOL - temperature down, credit card spending up :)
YZR500 OW81 Clone
NS400 Track Bike
RS250R NF5
TZ250T 2KM
TZ250B 3YL
427ci C5 Z07
Speed Freak
#117 Post by Speed Freak » Fri Jan 27, 2017 7:31 pm
Not that bad... Temperature up - costs for tires and fuel go up...
It`s somehow giving it a balance over the year :smt005
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#118 Post by Speed Freak » Sat Feb 04, 2017 11:00 am
Again small time consuming details...
Full variable hose clamp.
If you put it into an assembly the diameter is more or less automatically adjusted to the hose diameter.
At least I have to do it only one time - all other hose clamps are now copy&paste parts with some different dimensions.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Speed Freak
#119 Post by Speed Freak » Sun Feb 12, 2017 6:48 pm
+2°C in my garage and a friend found time to make some tools for me (simple pressing plates).
So I disassembled my 2 spare cranks.
Conrods are anyway damaged (small end bearing failed on 2) and another one has a big end bearing which was close to fail, completely blue which means it was very hot.
Don`t know what happened with this engine, got it with 2 completely destroyed cylinders.
Need to take some measurements, but as 2 big end bearings are blue I think it isn`t a good idea to even think about reusing the inner webs.
Has anyone experience with the Yambits crank webs?
Thinking about using 4 new crank webs and a set of new conrods together with new bearings (already at home).
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
#120 Post by silverstrom » Sun Feb 12, 2017 7:27 pm
If you decide to get rods from Yambits make sure you measure them carefully. There have been some issues with Yambits rods having external dimensions that are too big and the rods hit the cases when the crank rotates.
