Finally Started working on My Own Project....
hybrid
Site Admin
Re: Finally Started working on My Own Project....
#181 Post by hybrid » Thu Oct 15, 2015 1:54 am
WVWRZ500N wrote:
hybrid wrote:Did you make that throttle cable splitter yourself Bill?
Yes sir. Been making those for some years now. Work with any carb size too. $185.00 plus shipping.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Cool. I mated the stock one to two banshee splitters and it's working ok. One day I would like to incorporate a TPS though to work with the zeeltronic
Sent from my A0001 using Tapatalk
WVWRZ500N
#182 Post by WVWRZ500N » Thu Oct 15, 2015 10:13 am
That's the typical resolution to the aftermarket carb fitting. It's ok but not the best. What carbs are you using now?
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
wolfgangh
#183 Post by wolfgangh » Thu Oct 15, 2015 2:54 pm
I like my solution a lot, it incorporates a TPS as well as very low friction (important if you use 4 large carbs with heavy springs). I used the throttle splitter unit off an APRILIA RS250 and modified it to accept 4 cables out instead of the 2+1.
WVWRZ500N
#184 Post by WVWRZ500N » Thu Oct 15, 2015 3:51 pm
wolfgangh wrote:I like my solution a lot, it incorporates a TPS as well as very low friction (important if you use 4 large carbs with heavy springs). I used the throttle splitter unit off an APRILIA RS250 and modified it to accept 4 cables out instead of the 2+1.
Wolfgang,
I too like your design but find it either difficult to mass produce and for the average 500 owner the TPS is irrelivant. As for the heavy carb springs I cut them down to lessen the difficulty. I also incorporate the oil pump cable as well. Your's is super cool for sure though.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
#185 Post by Smoker » Thu Oct 15, 2015 7:21 pm
If only you were designing and selling cool parts to us mortals.... :cool:
hybrid
Site Admin
#186 Post by hybrid » Fri Oct 16, 2015 10:33 pm
WVWRZ500N wrote: That's the typical resolution to the aftermarket carb fitting. It's ok but not the best. What carbs are you using now?
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
I put 4 brand new PWK28's on mine. Nothing too fancy.
I did see your solution Wolfgang, but I don't really have the facilities to customise that like you have.
I even thought about potentially making something up that could adapt to the oil pump and control the TPS to move with the oil pump.
My bike is going extremely well at the moment since my latest mods, so I can only imagine how it would be with the timing optimised properly with a TPS.
rd84
#187 Post by rd84 » Tue Oct 20, 2015 10:49 am
Hi Bill,
Can I ask if there were any problems fitting the FZR750R/FZR1000 Genesis front end with R1 brakes. Any issues with the steering stem or clearance with the oil and header tanks etc ? - steering lock and stops ?
Thanks.
WVWRZ500N
#188 Post by WVWRZ500N » Wed Oct 21, 2015 12:37 pm
rd84 wrote:Hi Bill,
Thanks.
Paul,
Email sent.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
rd84
#189 Post by rd84 » Thu Oct 22, 2015 1:22 pm
WVWRZ500N wrote:
rd84 wrote:Hi Bill,
Thanks.
Paul,
Email sent.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Thanks Bill - much appreciated.
WVWRZ500N
#190 Post by WVWRZ500N » Tue Nov 17, 2015 11:21 am
Hello Fellow Club Members and Future Club Members:
So I finally bought a battery and started testing all the wiring now that it's back on the bike. Found a few things as one might imagine.
- Horn did not work at all. Removed it and hooked it direct to the battery still dead, replaced with another one I had, now good to go.
- My most anticipated wiring piece, the tail light integrator installation, well it wasn't working right to start. (Helps when you check the 30 year old bulbs first)! Spent 20 minutes looking at wiring diagrams and double guessing my wiring before checking the bulbs! End of that story is it's working perfect. I might even post a shorty video showing.
- Mounted the custom fender eliminator bracket I made.
- Custom soldered new ground wires to the front flush turn signals as the originals used the screws of which I eliminated early on.
YPVS servo cycles nice everytime the key is on. I haven't checked for spark but am pretty sure we should be good. Time will tell.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
WVWRZ500N
#191 Post by WVWRZ500N » Sat Jan 30, 2016 7:23 pm
DONE!!!!!!!
Just in time to hand deliver the World of Wheels car show application! What a monumental task this has been. My wife, bless her heart, has been more than patient and it's now done, done, done.
I'll have way better pictures done later but these were today just after final assembly. The sun wasn't out at all and the prismatic simply looks black, but it really shines in the sun.
Enjoy and thanks again for all the support and encouragement over these past few years.
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
Regards,
Bill Wilson
Wilson Performance
Lee's Summit, MO
816-377-3185
WVWRZ500N@aol.com
pstamper
#192 Post by pstamper » Sat Jan 30, 2016 9:11 pm
Very nice Bill. Came together well. I love the back of the bike. Is that wheel decals? Hope you have some warmer weather for some riding.
adr1an
#193 Post by adr1an » Sun Jan 31, 2016 12:13 am
Very nice Bill. Wonderful job. Looks like the rear tyre is glowing hot!! :grin: :grin: :grin:
#194 Post by Smoker » Sun Jan 31, 2016 4:03 am
I thought it was going to turn out quite gaudy, but I was wrong.
With the OEM bodywork - your colorful mods give it a nice pop.
Very well done! :smt038
Thanks for sharing the details of your build.
#195 Post by RuZty » Sun Jan 31, 2016 7:49 am
That came together nice. The red rear tire messes with my head, does it smell of raspberries when you do a burnout? ; )
