My 500 YZR screamer project
Re: My 500 YZR screamer project
Maybe with an offset woodruff key?
Hi Alex
I haven't built new gears but as Wolfgang wrote (thks), I have machined offset woodruff on the front crack.
It was not very difficult to realize but it was still a bit long to find the best offset.
Hope that can help you.
Bottom an upper pipes by Michel Ducros
- IMG_20140105_190042.jpg (123.67 KiB) Viewed 4711 times
- IMG_20140105_191138.jpg (89.77 KiB) Viewed 4711 times
- DSCN3027m.jpg (224.1 KiB) Viewed 4711 times
Some more old pics of the pipes and shock links.
The construction of the dry clutch
End of thr construction of the dry clutch.
And a part I like a lot for the thermostat's cut
Is the "thermostat's cut" part cast from aluminum?
I'm not sure how a part like this is made.
Very cool.
Very cool.
I can see that being welded from 3 pieces and seems nicely smoothened
Yes there are 4 aluminium parts. One come from the thermostat and the other parts come for oil radiator and machined parts.
Here are pics of the TZ 250 ignition trays assembly.
Painting job is finish now. I have to adjust the carbon fiber air boxes and restart my 500 to fisnish the engine set up.
Regards
Regards
Great job as usual love your paint scheme. Can't wait to see it all together.
- Contact:
Hello this is just an assembly for pictures because there are details to finish. Before 2 pics without fairing.
Rgds
Rgds
