RZ500 Restoration update
tacky1
Re: RZ500 Restoration update
#46 Post by tacky1 » Tue Sep 19, 2017 7:08 pm
You're doing a fantastic job, Attention to detail is top notch, Nice job, Your dad would be proud.. :smt023
Jarrettvp
#47 Post by Jarrettvp » Wed Sep 20, 2017 3:29 am
Thanks very much. I've thoroughly enjoyed it so far. The big test will be in the next few weeks when I try to get the thing set up to fire it for the first time in over 10 years. I'm also moving from the UK to Washington DC, so going to have to pack it up again. This will be the 4th continent the big will have travelled to.
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Jarrettvp
#48 Post by Jarrettvp » Sun Oct 01, 2017 5:12 pm
Big celebration day today. Got the wiring loom on and all connected up. New battery in and turned the ignition on - a few tweaks like swapping the wiring over for the indicators (left turn and right one comes on), but everything works! Need to check I've got spark next - most important thing!
https://www.dropbox.com/s/0p9cwrtzzyur7 ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/3ii2dwl8pnyya ... .jpeg?dl=0" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Kalim
#49 Post by Kalim » Sun Oct 01, 2017 5:30 pm
:smt023
rd84
#50 Post by rd84 » Mon Oct 02, 2017 9:31 am
Looks fantastic !
Jarrettvp
#51 Post by Jarrettvp » Sun Oct 15, 2017 7:14 pm
Got the radiator on this weekend and all the hoses connected up. Also got one set of carbs on. Realised I may need to take the radiator off again to tighten up the clips that hold the carbs in place (unless I have those really long tightening screws at the wrong angle.
https://www.dropbox.com/s/gnbfk3880ncdy ... .jpeg?dl=0" onclick="window.open(this.href);return false;
https://www.dropbox.com/s/dwugxx8t3r7lv ... .jpeg?dl=0" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
phildu31
#52 Post by phildu31 » Mon Oct 16, 2017 4:26 am
Jarrettvp wrote:Got the radiator on this weekend and all the hoses connected up. Also got one set of carbs on. Realised I may need to take the radiator off again to tighten up the clips that hold the carbs in place (unless I have those really long tightening screws at the wrong angle.
These screws should be reachable from under the radiator.
You can also use a 7mm head pipe.
Jarrettvp
#53 Post by Jarrettvp » Wed Nov 22, 2017 7:55 pm
Almost finished my restoration project now.
https://photos.app.goo.gl/3uj47RicsFHP7nxD3" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/dtWQ4HB3AWnN7kNI3" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/FdknIYlCkfX7Otan2" onclick="window.open(this.href);return false;
Got a coolant leak from some where though. I think it's from the two small hoss that go either side the main inlet / outlet hoses at the front of the engine. The carb heat shield on the right side is pressing against it and allowing coolant to pass over the top of the hose. Any ideas?
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
Jarrettvp
#54 Post by Jarrettvp » Wed Nov 22, 2017 8:11 pm
https://photos.app.goo.gl/UiAZvB07oLmH6Cqq1" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/5yEIPF4R1rMlaRdf1" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/pcsF2c1AfL53jOZi2" onclick="window.open(this.href);return false;
https://photos.app.goo.gl/Anqfnbra0G4k5F143" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
rd84
#55 Post by rd84 » Thu Nov 23, 2017 5:24 am
Fantastic restoration - wonderful quality - looks amazing !
Jarrettvp
#56 Post by Jarrettvp » Mon Nov 27, 2017 6:31 pm
Got the RZ500 fired up now. Resolved the coolant leak and the fuel overflow from the left lower carb. Just got to try to find out why the right side lower carb pours fuel out the overflow pipe (even when the bike isn't running). I tried the usual tapping of the bowl with a crew driver to free up the float. Any ideas from anyone?
See some photos of the colour returning to the bike. Nice to see something other than black.
https://photos.google.com/photo/AF1QipP ... oi4TofGvyO" onclick="window.open(this.href);return false;
https://photos.google.com/photo/AF1QipP ... viZRhC6ap6" onclick="window.open(this.href);return false;
https://photos.google.com/photo/AF1QipO ... 7oasYneOPm" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
tacky1
#57 Post by tacky1 » Mon Nov 27, 2017 9:54 pm
Jarrettvp wrote:Got the RZ500 fired up now. Resolved the coolant leak and the fuel overflow from the left lower carb. Just got to try to find out why the right side lower carb pours fuel out the overflow pipe (even when the bike isn't running). I tried the usual tapping of the bowl with a crew driver to free up the float. Any ideas from anyone?
Im getting an error when I click the links, 404, Links are broken
Jarrettvp
#58 Post by Jarrettvp » Tue Nov 28, 2017 6:57 pm
Try this.
https://photos.google.com/photo/AF1QipO ... WNMyab13vC" onclick="window.open(this.href);return false;
Yamaha R6
Yamaha RZ500
Ducati Panigale 959
#59 Post by silverstrom » Tue Nov 28, 2017 8:01 pm
Still can't see them. Says I need to log in with a google account to see the photos.
tacky1
#60 Post by tacky1 » Tue Nov 28, 2017 8:25 pm
Still not working
