BigGuy
#16
Post
by BigGuy » Sun Oct 21, 2018 9:19 pm
rd84 wrote:Ade SYM wrote:Paul
Did you paint the swingarm or just natural alloy?
Ade
Hi Ade,
It’s a natural brushed alloy finish - I had it bead blasted then lots of hours spent with scotchbrite.
Hi, I am also interested in this swingarm. Did you put a clear over it when you were done?
Shake "N" Bake!
rd84
#17
Post
by rd84 » Mon Oct 22, 2018 5:12 am
BigGuy wrote:rd84 wrote:Ade SYM wrote:Paul
Ade
Hi Ade,
Hi,
I haven’t clear coated it yet - but that is the plan - I’ll also do the frame as well so that it matches the swingarm.
Make sure the metal is warm but not hot before you spray the swingarm - the room you spray in should also be warm and with low humidity.
rd84
#18
Post
by rd84 » Sun Dec 02, 2018 10:49 am
A bit more progress...
The bikes now gone away to a bike shop for quite a few bits to be done that I'm not capable of doing.
The fairing and seat are available from King Carbon if anyone is thinking of doing a similar project.
#19
Post
by silverstrom » Mon Dec 03, 2018 12:56 am
Terrific build. Love that bodywork.
Is King Carbon UK based?
rd84
#21
Post
by rd84 » Mon Dec 03, 2018 12:54 pm
Hi,
I've spoken with Lee at King Carbon and they will do a special deal on the RZV500 / YZR500 fairing kit and seat unit....
Fibreglass Fairing £300 , Seat £180 , Delivery to the UK £20
Carbon Fairing and Seat £2000 if your missus can't think of anything to get you for Christmas !
https://www.kingcarbon.co.uk/Yamaha-race-fairings/
Mick C
#22
Post
by Mick C » Mon Dec 03, 2018 5:29 pm
Hi Paul,
Bike looks great...nice fit and finish with the fairing and seat, not always an easy thing to get right.
Mick
rd84
#23
Post
by rd84 » Tue Dec 04, 2018 7:49 am
Here are some shots of the subframe from earlier in the project... forward main subframe is by Gav at GIA, Nottingham, the aft part , oil tank and battery tray are by Nigel at NK Racing...
Nigel also did the rear sets, JL pipe re-route, Brembo rear brake, swingarm, yokes and front Brembo brakes. Discs are 320mm
ns86
#24
Post
by ns86 » Wed Dec 05, 2018 1:40 pm
Hi Paul, I ordered the front fairing in woven FRP and a windshield today. I have a standard type YZR500 seat which is my preference and will do my upper pipes like a YZR with short silencers. Lee said the front faring is also modified with additional venting and widened. Can you give the details? Thanx for putting this out there. It makes it a lot easier since you did the grunt work. This is a finite opportunity so I jumped on it! $850 CAD to Canada, about 1/2 the price a 1990 version Airtech would cost me, Dan
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
rd84
#25
Post
by rd84 » Wed Dec 05, 2018 4:49 pm
ns86 wrote: ↑Wed Dec 05, 2018 1:40 pm
Hi Dan,
I widened the belly pan 2 inches (50mm) and put in narrower radiator ducts to allow a standard radiator and airbox- I changed the trailing edge contour to allow for JL GP pipes or similar - I’ve put ducts and blisters on to allow for RZ500 water pump, clutch and generator - I put a duct in to cool a dry clutch if required and I put a duct in the bottom of the belly pan to give a cool air flow to the rear shock. The angle of the rear edge of fairing side is changed so that it is parallel to the frame to make it look like it belongs on our bikes - also the top fairing is profiled for the Gustafson 1991 YZR screen but others might fit - there are two holes each side in the mid section the rear one attached to the OEM airbox if required - with the rear fairing edge parallel to the frame you can then figure out the front brackets and front subframe position - you will have to figure out a new oil tank and radiator overflow tank.
I hope this helps and that you’re as happy with the final fairing from King Carbon as I am. The fairing is quite thin for lightness so you might need the odd extra bracket or brace to maintain the shape- I’ll report back on this as my project continues.
Rzv500rog
#26
Post
by Rzv500rog » Mon Jan 28, 2019 12:30 pm
Hi Paul, can you tell me where you got the curved hugger from for the R6 swingarm please. Roger
rd84
#28
Post
by rd84 » Thu Jul 25, 2019 7:32 pm
tacky1
#29
Post
by tacky1 » Thu Jul 25, 2019 7:52 pm
Gosh, That tank is just class Paul, The bike is coming along really nice....P
rd84
#30
Post
by rd84 » Thu Jul 25, 2019 8:06 pm
Thanks - it’s hard work at the minute - hundreds of small details that you never think of until the end of a project - I’m hoping it will be running by the end of this year.
