New member, with a yzr project
Hi I saw this forum.
Great to see that there are so many others, who like 2stoke races. I am from the Netherlands. I added some pictures of my project, but they are a little bit bad taken.
Maybe somebody can help me. I have a RS250 swingarm, but I can find a rear wheel that fits. I want to have 180 back tire, this must fit in the swingarm.
Next time I will add better pictures, or see my website at: http://www.tijger.org/bike/index.htm
Gr. Bas
Gr. Bas
Hello Gus,
welcome to the forum! I am building a YZR replica as well. So you bought the fairings from Enrique in Amsterdam?
I am using RS250 swingarm in my previous projectbike, with a 6.00" wheel from CBR900R and 180 tire. I had to machine the hub on both sides though to make it fit into the narrow swingarm.
Your frame looks like TZR250, so isn
Hello Bash
I have an Aprilia swing arm on my project with the two wheels (6 " and 5.5") and I have finished to put the 5.5 on the bike even if the 6" will give a better look (500 GP look). My 5.5" rear wheel comes from a 98 TZ 250 and the 6" from an YZR 500cc. I also think it's the best chose for track practice.
rgds
rgds
- Jordi YZR500
- Location: A small country with great people (Catalonia)
Hi Bash, and interesting project. Hope to see more pics.
Hi wolf, what about the clearance with the swinger in the rubber tyre area? What about the chain?wolfgangh wrote: I am using RS250 swingarm in my previous projectbike, with a 6.00" wheel from CBR900R and 180 tire. I had to machine the hub on both sides though to make it fit into the narrow swingarm.
AKA: Jordi RS 250
A SZR660 frame, that one is almost the same as a TZR250 frame. I have putt 320mm brembo's disks with 4 pistons per disk. USD front end. RS250 back-end. Self made spring/linkage system. VFR400RR tank, CBR900RR back wheel.cb4265 wrote:Hi Bash,
What frame & front end are you using?
Looks good so far, keep up the good work and the pictures.
Craig
I try to do my best.....
GR Bas
