Newbie on 500 forum (YZR 500 replicas)
Hy Guys
i'm new on 500 forum
i write something, and read a lot on 350 & miscellaneous parallel forum
because i'm an enthusiast of 350 models, but some times ago i started
my 500 custom project.
time to ending will be so far, now i can show ideas and work-in-progress
at that link,
http://www.2t-special.it/forum/viewtopic.php?f=14&t=498" onclick="window.open(this.href);return false;
for rolling chassis section
http://www.2t-special.it/forum/viewtopi" onclick="window.open(this.href);return false; ... =14&t=1129
for engine section
i think to have a lot of question to ask, because i not know well 500 engine
a special thanks to Wolfgang for supply bodywork
at that link,
for engine section
Alex
Re: Newbie on 500 forum
Ax-Racing wrote:Hy Guys
at that link,
http://www.2t-special.it/forum/viewtopi ... =14&t=1129
for engine section
wow 2 very fun links engine 11 pages
chassis was 47 pages to look on pictures on
incredible work.
RD 500 -84 looks fine
RD 500 -85 looks not fine
TZR 250 -87 for the winter
If I spell wrong
I will not be mad if you correct me!!!
If I spell wrong
Hi Wolfgangh
thanks for compliments
I haven't seen Micoproducts frame from live
but from your foto seems well done.
Yes, frame are three, but no one for sell, sorry
I want to build two replica of two different model year '89 and '98
and third frame is for a friend, he want to mount Ralf Kras engine conversion
Wolfgangh, i have a question, this morning i try to put under the bike the bottom part of your fairnig,
i think that i'll have interference problems with water pump and generator, may be the engine twisted down in front
another question, can you tell me the lenght (hole to hole) of R6 swingarm ?
Alex
Alex,
as you see I have modelled "Bubbles" into the lower fairings for the generator cover and the waterpump, so that I did not need to widen it at the bottom. If your engine sits in another position, these will be in the wrong place then.
Someone who builds such beautiful frames can easily change the position of these bubbles in the fairing I am sure...just a little "copy and paste", in this case cut-out and place in another position, and mold it in place with fibreglass matte and epoxy.
The R6 swingarm has a minimum length (rear axle in most forward position) of 565mm
best regards
Wolfgang
best regards
Wolfgang
Wolfgang, I never work with fiberglass before, then I'm al little scared about it, i'll try to do modification request, don't worry
on front left of bottom part of fairing there is a pronuciated square
bubble, how parts on your bike fill that shape ?
@ Andrew, I'll try to post some more pic's
if you want to spend some time to see all my pic's and work progress
from the beginning, you can follw this link
LINK
LINK
Alex
