Newbie on 500 forum (YZR 500 replicas)
Ax-Racing
Re: Newbie on 500 forum (YZR 500 replicas)
#151 Post by Ax-Racing » Thu May 01, 2014 4:29 pm
After v aramo meeeting, and seeing Wolfgang and Dubsey bikes, decided to try a R& swingarm swap on my 98 bike
here the object, and related hardware, I0m taking all dimensions and......
draw on CAD all changes needed, not a very difficult activity :grin:
Alex
racer38
#152 Post by racer38 » Fri May 02, 2014 3:39 am
Wow Alex, how did you CAD up the swingarm? Measure it or lazer scan? Some feat mate. I do CAD all day long (architect) and wouldn't fancy my chances drawing that up.
Must say, think the R6 arm is the right way to go. How did the big bore motor run??
Ax-Racing
#153 Post by Ax-Racing » Fri May 02, 2014 8:45 am
Measured and 2D drawing
Big Bore runs
i have to solve some fine tuning in ignition department,
and try to understand because dashboard doesen't work
I can't make any test until now, but hope to ride it soon
thanks :grin:
Alex
Ax-Racing
#154 Post by Ax-Racing » Wed Jan 07, 2015 5:06 pm
some updates
here two views of 98 rep. with r6 swinger installed and new front caliper
Alex
Ax-Racing
#155 Post by Ax-Racing » Wed Jan 07, 2015 5:13 pm
And..........
last autumn i decided to start another project based on 500 V4 engine, 1991 YZR replica
after get some parts, between Christmas holiday, i've started to work on new frame
Alex
wolfgangh
#156 Post by wolfgangh » Wed Jan 07, 2015 5:55 pm
Ciao Alex,
Breathtaking, unbelievable, awesome!
With all your perfectionism, you should modify your silencers with correct bent tips instead of the straight ones...
rd84
#157 Post by rd84 » Thu Jan 08, 2015 7:51 pm
Hi Alex,
Looks fantastic - really wonderful workmanship.
Thanks for sharing your progress - really interesting to see how you do some of the work.
ns86
#158 Post by ns86 » Fri Jan 09, 2015 1:10 am
Alex you are doing a Wonderful job. Is this a bit wider than the 3ma frame? Do you have spec's on your frame mods like you have for the swingarm?
1985 RZ500
1986 RG500
1986 RG500 C
1992 RGV500 WW ATR
1992 RGV500 LS
1985 NS500 Spencer p
1989 TZR500 Biaggi p
1984 RZV500 Rainey p
1994 NSR250sp R
1983 NS250 p
1987 RG250 WW p
1983 RG250 p
1988 YSR50 p
Kalim
#159 Post by Kalim » Fri Jan 09, 2015 4:57 am
I :shock: :shock: ... je :eek: :eek: :eek: , mais ... :shock: :shock: :shock: ... :smt007 :smt007 :smt007 ... je ... :shock: :shock: :shock: ... alors là ... :smt007 :shock: .
I had not followed this thread before actually.
Looking forward to see what's next !
David.
Ax-Racing
#160 Post by Ax-Racing » Fri Jan 09, 2015 10:16 am
ns86 wrote:Alex you are doing a Wonderful job. Is this a bit wider than the 3ma frame? Do you have spec's on your frame mods like you have for the swingarm?
of course, frame and all bike layout was drawn by CAD before build
3MA frame (4DL to be precise) id widened 40mm and shortened approx 35mm to fit longer swingarm
Alex
Ax-Racing
#161 Post by Ax-Racing » Tue May 12, 2015 6:36 am
https://www.facebook.com/alex.arletti/v ... nref=story" onclick="window.open(this.href);return false;
after a long period trying to solving wiring issues, finally last sunday i restarted
bikes, now setting and feeling on ignition parameters are good, and bikes seems to runn better.
next step will be setting carburettors and i wil be ready for first trackday
Alex
wolfgangh
#162 Post by wolfgangh » Tue May 12, 2015 7:20 am
Hi Alex,
absolutely stunning! I know what feeling it is to hear the engine running after all the hard work. What is this "singing" noise of your engine (sounds like a turbo) - is this coming from the clutch?
Ax-Racing
#163 Post by Ax-Racing » Tue May 12, 2015 7:56 am
my impression is that noise comes from camera
if you hear bike live noise is quite normal.
of course I removed double gears on crankshaft
and dry clutch rattle a lot if you pull lever.
Alex
rd84
#164 Post by rd84 » Tue May 12, 2015 9:48 am
A pleasure to see your work Alex !
kpke
#165 Post by kpke » Tue May 12, 2015 10:35 am
I didn't think I would get to look at that because I don't Facebook. But it opened up :smt023
Congratulations.
That is some stunning work.
