Rev counter playing up
Almac
#1 Post by Almac » Thu Jul 06, 2023 5:00 pm
I was out on a run the other day and my rev counter started to misbehave.
I started to read low and bounce about. I was thinking maybe a damper spring has gone in it as it seems a bit more stable when the bike is rev’ed at a standstill.
Anyone had similar issues? and can it be repaired?
Linx
Re: Rev counter playing up
#2 Post by Linx » Fri Jul 07, 2023 2:53 am
I had a similar issue. I found a new cable helped but didn't cure it completely.
:smt006 Current Bikes
Past Bikes Include
Almac
#3 Post by Almac » Sat Jul 08, 2023 10:21 am
Thanks, I’ll recheck the wiring but it was replaced a couple of years ago as part of a Zeel upgrade.
Could be the plug in the loom.
Twinsport
#4 Post by Twinsport » Mon Jul 10, 2023 3:55 am
Is the battery fully charged and/or is the bike charging as it should? Sluggish rev counter is usually a sign of low charge on the battery on these bikes.
Almac
#5 Post by Almac » Mon Jul 10, 2023 5:06 am
Yes, brand new lithium battery fitted.
It’s more the needle bouncing/moving erratically than moving sluggish.
I haven’t had much time of late to investigate, hopefully be able to borrow a replacement gauge from my friend in a few weeks as a quick check it’s not the rev counter before I start digging deeper into the wiring.
Almac
#6 Post by Almac » Sun Jul 30, 2023 2:00 pm
Wee follow up.
Sorted the rev counter, it wasn’t broken.
Same issue I had last year when I fitted a Zeeltronics. The Zeel generates too high a voltage for the rev counter input. I fitted a zener diode to cut the volts down, had to fit another diode (2 in series) to chop a little more volts.
