RZ500 and Parts for Sale
Got some stuff you need to move out? Do it here! Please, NO vendors
ssmacdon
#1 Post by ssmacdon » Sun Jul 30, 2023 7:35 am
Hey There,
Have the following for sale, located in Toronto, Canada:
Bike:
-Clean Ontario title in my name
-Complete except for of the obvious things you can see in the pics (rear fender, chain guard,etc), needs the plastic piece that holds the rad cap and a coolant hose or two
-Went through the motor when I built my last RZ500, complete except the clutch push rod ball, maybe a seal or gasket, no obvious problems except the water pump drive gear has a tooth broken off
-Needs to be rebuilt, top and bottom end
Additional Parts:
-Too much to list, please look at the pics
-Rolling chassis with clean Ontario title in my name
-Motor with bottom end intact, looks rough but the cases look good
-5 cranks and additional crank parts (NOS rear crank center section), balance shaft
-2 sets of carbs
-Set of exhaust pipes
-Transmission, other bottom end parts like kick gears, oil pumps, water pumps, etc
-9 cylinders, most std bore, few may be 0.25 over, 7 cyl heads, some have some ring damage
-Set of NOS 0.5 over pistons and 1 std piston and ring kit
-CDI, power valve controller, 2 wire harnesses
-Power valve motors, linkages, valves
-etc. etc just about 1 or 2 of everything needed to put together another bike
Pics are here:
https://flic.kr/ps/42JARA
I'm moving soon and losing my storage, so must go asap. Looking for $5,300 US/$7,000 CDN for everything. I consider this cheap but would be happy if a forum member bought it as it has been a great resource for me over the years. Want to sell it all together, don't have time to sell individual parts (sorry, don't ask). Would make sense for someone to sell off extra parts and use the $$ to rebuild the bike. Will be a big load, need a good size truck I think. I don't have time to deal with shipping, so needs to be picked up.
If you are interested send me a pm, send your number if you want me to call and talk about it.
Thanks,
Scott
Scott
Rd500F1
Re: RZ500 and Parts for Sale
#2 Post by Rd500F1 » Tue Aug 01, 2023 6:03 pm
Wow that's a lot of kit for the money, unfortunately I'm in the UK. Good luck with the sale.
ssmacdon
#3 Post by ssmacdon » Wed Aug 02, 2023 11:04 pm
Thanks! :grin:
Scott
cainpole
#4 Post by cainpole » Fri Aug 04, 2023 4:43 pm
Scott I sent you PM.
cainpole
#5 Post by cainpole » Fri Aug 04, 2023 4:56 pm
Scott, I sent you a PM.
ssmacdon
#6 Post by ssmacdon » Sat Aug 05, 2023 6:54 am
Hi cainpole, I replied to your pm and also sent an email
Scott
andy
#7 Post by andy » Mon Aug 07, 2023 12:39 pm
Hi Scott, note sent. cheers
ssmacdon
#8 Post by ssmacdon » Tue Aug 08, 2023 12:00 pm
Thanks for the interest, this has all been sold
Scott
