I have found a ball bearing and a needle roller bearing replacing the above.
Ball bearing has dimensions
25 ID 47 OD
and needle roller bearing has dimensions
20 ID 35 OD
Both have inner rings and they are direct replacement for the OEM parts that are NLA from Yamaha.
George
93311 42056 and 93311 92557 gearbox bearings
The bearings I found are not the same as the OEM. They have the same dimensions but they are of a different type.gus wrote:George, glad you posted that I'm leaving monday morning to head back over I'll do the other stuff on my list and scratch the bearings off the list thanks
If you could find the OEM I can always get a pair or more.
George
Bearings
Are these the main crank bearings. Not sure if its the same as my old 4lo mains but my local dealer has said the bearings are of a different clearance class as normal bearings to account for the added heat generated by the engine. They are graded as C3 or C4 bearings (cant remember which)
Dont know how true this is but it may be something to think about before using normal bearings in the engine.
Jon
Jon
Re: Bearings
They are not the crank bearings. The crank bearings are rated C3. Normlly you can find the crank bearings in your local bearing shop. If you need further info on the crank bearings let me know.lcjonny wrote:Are these the main crank bearings. Not sure if its the same as my old 4lo mains but my local dealer has said the bearings are of a different clearance class as normal bearings to account for the added heat generated by the engine. They are graded as C3 or C4 bearings (cant remember which)
Jon
George
Re: 93311 42056 and 93311 92557 gearbox bearings
Hi George -would i be possible that you have the part numbers for the replacement bearings you have found. Your assistence will be highly appriciated - Rgds Johngeosot wrote:I have found a ball bearing and a needle roller bearing replacing the above.
25 ID 47 OD
20 ID 35 OD
George
You'll find them at the link below
http://www.ebay.ca/itm/RZ500-RD500-RZV5 ... Oj&vxp=mtr" onclick="window.open(this.href);return false;
