Belly Pan RZV500R
RZ-RD-RZV.... and everything in between
Blobber
Belly Pan RZV500R
#1 Post by Blobber » Wed May 20, 2009 11:06 am
A bit of an anorak question but very important non the less as I dont want to break my freshly repaired and brittle belly pan!
I have de-restricted and now in the process of simpathetically recommisioning my bike. I am at the stage of fitting the body work plastics however, when I bought the bike the belly pan was missing one of the rear brackets that fix it to the frame. Having had the belly pan plastic welded and found another similar mounting bracket off a wrecked belly pan I noticed that it seems a little tight to fit. Now I'm not sure if its because of the repair or because they are just like that or have I used an incorrect rear bracket. When I look on this message board there is a picture that is always referred to that shows the belly pan with brackets fitted for the RZ/RD. One of the bracket mounts appears off set (left hand side) by approx 5mm. I am using two straight brackets without the off set. With the off set the belly pan would be even more difficult to fit.
The question I am getting round to is; does anyone know if the belly pan brackets for the RZV are the same each side or are they like the RZ/RD with specific right and left hand brackets? Not as daft a question as you may initially think because the frame dimensions are different so why not different brackets.
Any replies much appreciated as its doing my head in especially as you cant just go and buy replacements.
Thanks - Trevor, Lancashire England
STOKEYSRD
#2 Post by STOKEYSRD » Wed May 20, 2009 12:10 pm
yes the brackets are diferent 1 ofset 1 straight see jackson 40 's rebuild there is a pic of them just checked mine to make sure hope this helps. It is ok to fit the belly pan without them as not all bikes had them & you cant get new ones & i've onle see 2 sets come up on flebay
Alan
Blobber
#3 Post by Blobber » Wed May 20, 2009 12:31 pm
Hi mate - thanks for reponding. Are you talking about RD/RZ or RZV? I know they are different on the RZ/RD but what about the RZV with ally frame?
Trevor
STOKEYSRD
#4 Post by STOKEYSRD » Thu May 21, 2009 4:10 am
it's the same for both bikes
Alan
Blobber
#5 Post by Blobber » Thu May 21, 2009 4:29 am
Alan - My conclusion is that my belly pan must have a degree of distortion because there is no way I could fit an off set bracket to the left side without breaking the plastic mount. I must admit that the bottom of the belly pan does seem a little closer to the left exhaust (virtually touching) than the right (approx 5-10mm away).
Thanks again for your help.
Trevor
jackson.40
#6 Post by jackson.40 » Sat Sep 19, 2009 4:33 am
Here is a photo of a new rzv500 belly pan showing the brackets which are the same as the rd/rz 500.
Blobber
#7 Post by Blobber » Tue Sep 22, 2009 10:13 am
Thanks for the photo mate - very interesting. Can you confirm then that both the left and right hand belly pan brackets are the same on that NOS RZV belly pan? As I was under the impression that the right hand one was different - or is that on the RD only and not the RZV - how bloody confusing.
I hope both are the same as I have two the same from a spare belly pan.
Many thanks
Trevor
jackson.40
#8 Post by jackson.40 » Tue Sep 22, 2009 2:33 pm
Hi Trevor.The left and right hand brackets are different.The left and right hand brackets that are on the rzv belly pan and the rd belly pan are the same.I got mine out the loft today and took a better photo to show the difference.Hope this helps.
Regards Steve
aaronmvrider
#9 Post by aaronmvrider » Tue Sep 29, 2009 7:46 am
are these parts still available to buy
could you do a simple diagram for reproducing these
Aaron
my rides
rz 500 1984
2 x rz 350 1984
mv agusta f4 1000 2004
Guillaume
#10 Post by Guillaume » Wed Nov 18, 2009 4:43 pm
simply mad...
but so good for my collection pic :D
so tank's Jackson for your job, you'r page one my site, is the best popular
http://www.500v4.com/yamaha_500_rdlc_50 ... loupe.html
take care ;)
jackson.40
#11 Post by jackson.40 » Wed Nov 18, 2009 7:08 pm
Thanks Guillaume,looks like my rzv is going the same way :shock:
Guillaume
#12 Post by Guillaume » Thu Nov 19, 2009 5:42 pm
i love it :grin:
