Hi just getting round to firing up my 500 for the fist time since rebuild I'm just trying to fathom out which HT lead to what cylinder ? Am I right for the top coil ? Left to 3 right to 4? If I am it's just the lower coil I need advice on thanks.
Correct position if HT leads
Re: Correct position if HT leads
don't think it matters from an electrical standpoint, either way will work.... for the lowers, one lead is definitely shorter than the other so it's easy to figure out which one went where from the factory
Bit of a bugger but mine are both the same length with no numbers on?
Ofcourse it's a wasted spark system, someone donate me a few brain cells !
lol there ya go rugbyrhino!!!!
She runnin yet????
She runnin yet????
