Please explain how the 90 degree valve stems fly off at high speed. The retaining nut on the inside of the wheel is the same as on straight valve stems.RZtuner wrote:New tires and 90 degree valve stems from Kurveygirl.
A word of caution on the 90 degree valve stems,...... have seen these fly off at high speed.Not a good idea.
Seen the same thing with fitting bling "skull" valve caps..... will rip the valve right out of the rim.
Both, my Marchesini and BST carbon wheels came with 90 degree valve stems, and I've used 90 degree valve stems from Curvy Girl as well, with no issues.
