SRX250 Fuel petcock
thumper580
SRX250 Fuel petcock
#1 Post by thumper580 » Sat Aug 12, 2017 11:42 pm
It appears that the srx250 petcock (51Y-24500-01-00) is the same as the 500 petcock (47X-24500-01-00). Is this correct. Same number sequence except for the 47X vs the 51Y. It looks like it has the same/similar fittings...... Anyone else check this out?
Mike Cichetti
Re: SRX250 Fuel petcock
#2 Post by Mike Cichetti » Sun Aug 13, 2017 10:59 am
Petcock is the same but outlet is smaller. I swapped it out with the one from my old leaking one.
thumper580
#3 Post by thumper580 » Sun Aug 13, 2017 11:45 am
Mike Cichetti wrote:Petcock is the same but outlet is smaller. I swapped it out with the one from my old leaking one.
Mike, so you are using the SRX petcock?? or did you pull the guts out of it to repair the 500 petcock. If you are using the SRX petcock, does it flow enough fuel?
Thanks.
Mike Cichetti
#4 Post by Mike Cichetti » Mon Aug 14, 2017 10:31 am
I removed the outflow pipe from the SRX and used the outflow from my old petcock. It's a press fit.
thumper580
#5 Post by thumper580 » Mon Aug 14, 2017 1:59 pm
Mike Cichetti wrote:I removed the outflow pipe from the SRX and used the outflow from my old petcock. It's a press fit.
Thanks!!
