Yes I have , no plugs provided with it just lots of cable tail ends , pAndy500R wrote:Hi Paul , the zeeltronic just replaces the
Standard control boxes , you have to swap
The plugs over so no need to mess with
The loom !!
Have you purchased one already ??
zeeltronic
Re: zeeltronic
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
Like someone said you can buy new plugs or use your own
Off the old units
Off the old units
Re: zeeltronic
You're right Martin !
Falsely assumed that the Zeel PCDI-24V was a magneto-CDI by rapidly looking at its wiring diagram : http://www.zeeltronic.com/manuals/RD500 ... 4V_con.pdf" onclick="window.open(this.href);return false;
In fact, it takes power from the YPVS connector and is, as you said, a DC-CDI ! ....
A little regression compared to original CDI : without a charged battery, bike won't start, contrary to original bike who can start even without a battery.
Re: zeeltronic
i sold the old units long time ago to help fund the zeel andy .Andy500R wrote:Like someone said you can buy new plugs or use your own
Off the old units
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
is that the full set and all i need for the zeel john ? psilverstrom wrote:This guy has the plugs https://www.ebay.ca/itm/Yamaha-RD500-RZ ... Sw-xVZ9KA5" onclick="window.open(this.href);return false;
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
The eBay plugs are the same as those on the CDI and PV controller you sold and are meant to save you the grief of removing them from your CDI and PV controller Paul. I've done business with that seller in the past and had no problems. Can't remember what I bought though. The plugs are something new from him and look to be 3D printed. A good solution for an old problem.
Re: zeeltronic
The PCDI24 actually is what you'd refer a magneto CDI. It draws the energy required to create the spark from the source coils plus it needs a 12V supply because the ECU that does the spark timing is based on a 12V circuit.phildu31 wrote: Falsely assumed that the Zeel PCDI-24V was a magneto-CDI
No 12V supply = no spark.
Then there's the PDCI24 which is a DC type CDI. It doesn't need source coils as it draws the spark energy from the 12V supply. (Obviously this one will draw much more current than the PCDI)
I'm not really happy with Boruts product naming (PCDI and PDCI) as people all the time mistake them or think there's just one product aka "the Zeel ignition". Furthermore he offers a variety of single boxes controlling all-in-one or just ignition or just PV.
Basically if you're told somebody uses "a Zeel", you pretty much need to ask what exactly was used as there are different possibilities to skin the cat.
Ignitech has much less confusion as they only have DC CDIs and they're all named DC-CDI xx.
(just note that on all RD500s I had in my workshop the Ignitech didn't work properly. Seems like an EMV issue. For the RD350 there were no such issues)
Re: zeeltronic
martin i have the PCDI-24V so what do you mean about the coils ? should this be the one i use ?
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
"source coils" is the red/green/brown part on the stator.
If you have that and they're OK, it'll work just fine.
With a PDCI you'd have the option to run total loss (=remove rotor/stator) for race use.
Re: zeeltronic
well hopefully there ok mate , cheers thanks for that , ps
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
may be a silly question but whats the best way to clean the old loom . in other forums iv read lads putting them into the dishwasher or washing machine is this ok to do or will this just cause all the termanals to rust up , any advice ? ta
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
john im also fitting a translogic dash (TLS-MD3-12) are there fittings on the market as per the zeel to make this a plug and go or do i have to cut into the loom for this , again no fittings came with it ? ta pssilverstrom wrote:The eBay plugs are the same as those on the CDI and PV controller you sold and are meant to save you the grief of removing them from your CDI and PV controller Paul. I've done business with that seller in the past and had no problems. Can't remember what I bought though. The plugs are something new from him and look to be 3D printed. A good solution for an old problem.
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
This is a well known and reputable shop Paul. Known well among the RZ350 guys and great service. I've bought from them many times. I have never bought connectors there. If you find overseas shipping to be expensive I'm sure one of the US based members would be happy to help you.
https://www.economycycle.com/shop/bulle ... sold-each/" onclick="window.open(this.href);return false;
I ordered this kit on eBay a few days ago. https://www.ebay.ca/itm/40-Set-Motorcyc ... SwOfdZsOiX" onclick="window.open(this.href);return false;
Re: zeeltronic
hi john , the rear tail light im fitting in of a r1 or r6 i think . the wires that come out of it is yellow , black , blue . what do i connect to what on the original rd500 loom at the tail end . there are built in indis in the r1 lamp as far as i know so i am not fitting 500 indis so want to get rid of the not needed wires can you help mate ? ta paul s
my bikes.
CBX 1000 , RD 500 .
CBX 1000 , RD 500 .
Re: zeeltronic
Black wire is ground, connect it to the black on the loom.
Yellow wire is brake light, connect it to the green/yellow.
Blue wire is tail light, connect it to the blue/red.
