Streetfighter RZV Roller
Jeff B
Re: Streetfighter RZV Roller
#406 Post by Jeff B » Thu Apr 26, 2018 2:26 pm
Smoker wrote:
Jeff B wrote:My braced swing arm required the frame chop on the right side only. Not sure about the R6 swing arm though.
Interesting. Would love to see pics of your frame chop.
The frame does not need to be chopped to use the R6 arm, just minor modifications, like moving the YPVS motor, and maybe removing a small bracket.
I would be chopping to fit straight pipes. Even if straight pipes would fit without chopping, I may want to get rid of the curved support tubes. They look kind of weird without the pipes on the outside. We'll see.
The Aprilia Mille swingarm I'm using is very wide up front. My pics are all on Photobucket. :( I'll have to take more.
I misunderstood why you are chopping the frame at first.
#407 Post by Smoker » Thu Apr 26, 2018 6:44 pm
Jeff B wrote:The Aprilia Mille swingarm I'm using is very wide up front. My pics are all on Photobucket. :( I'll have to take more.
No problem. I appreciate any input that might help.
If your photobucket pics are posted somewhere, I might be able to "fix" them:
#408 Post by Smoker » Thu Apr 26, 2018 6:51 pm
Got the dimensions for the OEM swingarm washers. :smt006
I believe they're hardened steel, but hopefully, titanium will work - at least for a while.
Trying to machine up a pair, now.
Ordered the crazy expensive dust caps from Singapore. Just want to keep moving forward.
#409 Post by Smoker » Thu Apr 26, 2018 7:05 pm
I know that sometimes OEM parts deviate in size, but I got a measurement of about 39.1mm for the OD of the pivot tube on the OEM swingarm.
In this drawing, I see 39mm, but I also see 40mm - and I'm not sure what the 40mm measurement is for? Sorry, if it's an obvious answer.
#410 Post by Smoker » Fri Apr 27, 2018 12:44 am
:smt010 :smt010 :smt010 :smt010 :smt010
Hello
Thank you for the e-mail.
Sorry, this is sample
I can not make it anymore
Thank you very much.
QualityWorks JAPAN
Jeff B
#411 Post by Jeff B » Fri Apr 27, 2018 2:14 pm
Smoker wrote:I know that sometimes OEM parts deviate in size, but I got a measurement of about 39.1mm for the OD of the pivot tube on the OEM swingarm.
It's really difficult to say from this print. My guess would be 40mm tube with a 39mm chamfer or 40mm tube with the ends turned down to 39mm.
Ron57
#412 Post by Ron57 » Sat Apr 28, 2018 1:44 am
Hi Pete, machined down for the dust cover.
Cheers Ron.
#413 Post by Smoker » Sat Apr 28, 2018 4:27 am
Ron57 wrote:Hi Pete, machined down for the dust cover.
Cheers Ron.
Was just going to post the same, based on this other drawing. Thanks for the photo!
#414 Post by Smoker » Sat Apr 28, 2018 12:57 pm
Finally figured out WTF is going on with the R6 hugger.
Both carbon huggers I ordered were too small. Too small is a relative term, so, the center-to-center distance between the left and right mounting holes on the huggers is 150mm and the swingarm measures 165mm. The distance from the front hole to the side holes is also too small on the huggers.
Figured the huggers are no good, or the swingarm is bowed/bent. Ordered a new OEM R6 hugger. Unbelievable! OEM is exactly the same size as the carbon huggers. Never seen an OEM part so far off on size. And the same swingarm and hugger part number were used for about 10 years.
Couldn't believe it, so had a friend measure a different R6 swingarm. Exactly 165mm. Nothing wrong with my arm.
Problem is, when the carbon part is stretched to fit, all the pressure is on this tiny 2mm piece. Guess it must work, lots of people are using carbon huggers.
#415 Post by Smoker » Sun Apr 29, 2018 3:00 pm
New titanium brake caliper spacers.
#416 Post by Smoker » Sat May 05, 2018 4:31 pm
Got the OEM pivot bush & bearings, and titanium thrust washers. Just waiting on the OEM dust caps.
#417 Post by Smoker » Tue May 08, 2018 9:18 am
First cardboard mockup of my footpeg bracket design. Still have several things to fix and try out. Won't need heel guards if I keep them full size.
If it looks a little off, it is. Need to check that better next time.
Clearance to the swingarm is a little over 1/4 inch, as is.
#418 Post by Smoker » Wed May 09, 2018 7:48 am
Still trying different footpeg bracket mockups.
Will try to finish this little bugger later today.
#419 Post by Smoker » Sat May 19, 2018 1:26 pm
Received the 2 pivot tube end caps.
Paid more than double the price because they're backordered until June.
Advert says -
Condition: NEW
Surface Finish: MINT
Seller: ezpezie
Photo from the advert:
Received this:
#420 Post by Smoker » Thu May 31, 2018 5:30 pm
Never tried to design a swingarm, so I'm learning a lot.
Looks like reducing the length of the (R6 style) arm will cause the upper brace to hit the frame. Lowering the upper brace puts it closer to the chain. Also, moving the sprocket forward puts the chain closer to the upper brace. Need to do some careful measuring before making changes.
Pulled out & split the casings to install the bearing, output shaft & front sprocket. Now, I can measure from the chain run.
Was thinking about gullwing in this style, but not right for this bike. There's no shock in the swingarm, so, all 4 tubes can be centered and welded to the pivot tube. Much better for clearance issues. Could still gullwing the lower tube.
Still waiting on OEM pivot tube parts. Sent the jacked up parts back and ordered new ones.
