It is currently Fri Aug 17, 2018 3:05 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: I'm not grounded, but it should be (turn signa vs rpm gauge)
PostPosted: Fri May 26, 2017 11:37 am
I think i have a ground issue: When the turn signal is on, my rpm gauge is effected, shown by the gauge who moves up and down.
I'm trying to find the ground cables and connections: Could someone point me out where they are on the bike before i dismantle it completely?
I want to look at them all, due to strange issues (brake light don't allways does it etc)/
Much appreciated in forward,
Richard
 Post subject: Re: I'm not grounded, but it should be (turn signa vs rpm ga
PostPosted: Tue Jun 13, 2017 10:34 am
Hi Richard,
Check the state of the battery charge before you do anything.
PostPosted: Thu Jun 22, 2017 5:58 am
I'll do, merci.
I thought there would some other issues then.
PostPosted: Thu Jul 13, 2017 11:23 am
Measured the battery, only 9,5 V.
Started the engine, only ca 10 V on the battery.
Charged it till ca 12,9 V, battery seems good (YPVS control works fine now)
Should i change the stator or are there other things to check?
Regards,
Richard
PostPosted: Thu Jul 13, 2017 1:11 pm
Start with the regulator-rectifier. Sometimes it is just the reg-rec having a poor ground. It is grounded through the case/body so a cleaning and light sanding as well as a clean frame is necessary. If it isn't a poor ground you can test the reg-rec with a meter if your meter has a diode setting. It is often easier to swap the reg-rec. There are plenty of them around. Same unit used on TZR250 and RZ350, as well as others.
Check the reg-rec connector as well. Contact cleaner on both plugs.
If that doesn't fix it for you your next step is to meter the stator.
PostPosted: Sat Jul 15, 2017 10:09 am
Just ordered new rectifier/ regulator, just in case. If it's in i'll look into it.
Thanks!
PostPosted: Mon Jul 31, 2017 12:50 pm
Okay, rectifier/ regulator is okay, grounding is good (measured on several points)
Stator: Allso good.
Changed the coil: Bad connection on wire/ spark plug (had one in stock).
If it isn't solved i'll try extra grounding, i'm down in ideas... Ground from battery is a little bit tiny. First ride the bad thing. :smt003
PostPosted: Tue Aug 01, 2017 10:51 am
To fix a problem on mine I ran a separate ground wire from the rectifier to the frame and it was cured. I would have to look at my notes to find out what the exact symptom was. My rectifier is relocated on a powder coated tray under the fuel tank so it needed the discrete ground connection.
As John said aboveā€¦this is potentially an easy fix if it is a rectifier ground problem. Sounds like maybe it isn't though.
Good luck.
1985 RZ500 (R6 suspension & body work)
(8) RZ350's
2006 R1 LE #158
Gold Wing/Trailer
PostPosted: Fri Aug 04, 2017 12:32 pm
Drove it today, issue solved: Thanks for the input guys :smt041 !
PostPosted: Thu May 31, 2018 10:59 am
An update: Thought it wa solved, but problem started after a while again.
After the winter i noticed that the battery was down, bought me a lithium one.
Now i can say (after 2 month) that this solved the prob.
