It is currently Sun May 20, 2018 7:42 am
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
 Post subject: bellypan stone bracket
PostPosted: Thu May 10, 2018 6:41 pm
is there anywhere i can buy these now ? https://www.cmsnl.com/products/mole-1_4 ... vS70YYh3q0
my bikes.
YL1 , AS3 (2) , YAS1 (2) , LC 350 ,
RD 400 , 400 DAYTONA , KH 250 s1 ,
CBX 1000 , RD 500 .
 Post subject: Re: bellypan stone bracket
PostPosted: Thu May 10, 2018 6:46 pm
https://m.ebay.co.uk/itm/RD500-RZ500-RZV-2x-FORMTEIL-FUR-VERKLEIDUNGSGITTER-47X-28345-GUMMI-MOLE-1/382457505763?hash=item590c3e67e3:g:ShkAAOSwhpZZ58iY
PostPosted: Thu May 10, 2018 6:50 pm
these are the parts that hold on the bellypan mesh yes ?? ta
my bikes.
CBX 1000 , RD 500 .
PostPosted: Thu May 10, 2018 6:56 pm
rd84 wrote:
these are the parts that hold on the bellypan mesh is this correct mate ?? ta
my bikes.
CBX 1000 , RD 500 .
PostPosted: Fri May 11, 2018 2:11 am
You also need the top bracket - the dampers above just protect the bodywork and allow the top bracket to grip the bodywork - if you don't have one they are available from one of our forum members.
Ps the rubber dampers can be replaced by a short strip of u section rubber like you get on the screen edge trim for example - this is not 100% accurate but is cheaper and works ok.
Also lockwire the mesh section to something nearby so it isn’t lost if it comes loose.
PostPosted: Fri May 11, 2018 2:47 am
http://rzrd500.com/500phpBB3/viewtopic.php?f=6&t=14693
PostPosted: Fri May 11, 2018 5:21 am
rd84 wrote:
Thanks for advice and help mate , p
my bikes.
CBX 1000 , RD 500 .
PostPosted: Fri May 11, 2018 10:03 am
rd84 wrote:
would you have a picture of how its fitted to the fairing and bracket please , yes i bought a top bracket from one of the forum lads , cheers
my bikes.
CBX 1000 , RD 500 .
PostPosted: Sun May 13, 2018 3:23 pm
Does this help ? .....
The bottom mesh is slid down into the bottom of the fairing aperture - the top bracket is slid down until it grounds onto the top of the mesh - the moles are positioned on the fairing edge so they lie under the side protrusions of the top bracket - the top bracket screws are tightened to clamp the top bracket onto to the moles and fairing - the top bracket can't move in theory and in turn this stops the mesh from moving up and falling out - in practice it can so wire the mesh to the YPVS debris shield so if the assembly comes loose you don't lose it since they are a little bit expensive to replace nowadays.
PostPosted: Sun May 13, 2018 4:16 pm
It's nice to have the stone guard, but not essential to install it. Unless you are riding in gravel it's a mostly useless item. I have mine in storage (so the bike is complete) but I won't install it. If you do decide to actually install it on your bike use a tether as in the photo above or risk losing it. Many have fallen off.
1985 RZ500
1985 RZ500 Project Bike
PostPosted: Mon May 14, 2018 4:12 pm
Nice one Paul, the tip about wiring it to the YPVS shield is a great idea.
PostPosted: Tue May 15, 2018 2:07 pm
Great info and pics lads ta , just one more question on the two stroke oil bracket I seen on a video somewhere that the bracket swivels round to allow filling is this the way it should be as mine is just bolted down ? Ta
my bikes.
CBX 1000 , RD 500 .
PostPosted: Tue May 15, 2018 5:34 pm
It swivels P, The bracket has a bolt that allows it to swivel
PostPosted: Tue May 15, 2018 6:57 pm
any pics of the correct type paul as im lost on this one ? ta
my bikes.
CBX 1000 , RD 500 .
PostPosted: Tue May 15, 2018 7:30 pm
1985 RZ500
cron
