It is currently Sun May 20, 2018 7:31 am
Post new topic Reply to topic  [ 10 posts ]
 Post subject: PV Control Box HELP
PostPosted: Sun May 13, 2018 8:15 am
I completed a ground up restoration on my RD, it smoked a lot when first started which wasn't a problem as I was running it in. However, I was going to re-set the oil pump and found it wouldn't close, on further examination I found that the Power Valves were always in the open position even when the ignition was turned off. I was under the impression that the valves should close when the ignition is turned off then when turned on it should be open, close, open then when you again turn the ignition to off the valves should close and in doing so the oil pump closes also.
To clarify: my valves are open when ignition is off then the sequence goes close, open when ignition is turned on, in turn this means the oil pump is at half open when ignition is off and goes close, half open when ignition is turned on.
As this is my first RD500 I am a bit of a novice on these settings so my questions are should the Power Valves be closed when ignition is off and when turned on should they be open and what setting should the oil pump be at IE closed or half open when ignition is on?
Hopefully I am explaining things correctly, if not I will clarify any points necessary.
 Post subject: Re: PV Control Box HELP
PostPosted: Sun May 13, 2018 2:59 pm
https://www.youtube.com/watch?v=yg96jsGoy2M
PostPosted: Mon May 14, 2018 6:52 am
Hi Silverstrom,
Thanks for taking the time to reply, I did however go online and research what I could and viewed the link you posted, however, what I was looking for was someone who could tell me that the valves should be closed or open and the oil pump should be closed or half open when the ignition is off.
I believe that the valves and the oil pump should both be closed and therefore my PV box wasn't working correctly, but I had someone tell me that my PV box was working correctly and if this is true then the valves should be open and the oil pump at half open when ignition is off (still don't believe this is correct).
I even changed over my servo motor cables to see if they were wrong but this only reversed what was happening.
Any help would be appreciated.
PostPosted: Mon May 14, 2018 7:10 am
Sounds about right.
Switch ignition on, sound ssstsstsst, after sound ends, vales are OPEN.
If engine is started now, valves go to CLOSED position. If you rev it above around 6.5k they start opening and should be fully open shortly above 8k (all stock box).
Different boxes may alter the actuation rpms, but all behave principally the same.
PostPosted: Mon May 14, 2018 10:54 am
Hi Martin,
I don't know if I'm explaining properly, my valves are open when ignition is off and they never close, my oil pump never closes also.
I thought it would be the PV controller but am open to trying anything else that it may be?
PostPosted: Mon May 14, 2018 3:04 pm
If they are open and you switch on the ignition they should move and you hear a ssst ssst sound.
If that's not the case something is wrong. Sometimes as easy as a blown fuse or loose connection but often it's the control box.
If ignition is switched off, nothing will move as there's no juice to do so. That's normal.
If you meant you have switched on the ignition and it stays open and does nothing: That's normal as long you don't start the engine.
It moves when you start and rev up. If that's not the case see the above section.
If the controller is blown, I'd always tend to buying a Zeeltronic ignition and PV box. Not that is fixes the issue at just a few bucks more than a 30 yo used bix, it easily adds 10 or more horses with a decent curve.
PostPosted: Mon May 14, 2018 6:35 pm
Thanks Martin,
This is where the confusion arises, the manual and any videos online all show the valves closing, and the oil pump returning to closed also, when the ignition is turned off.
My valves stay open (when ignition is switched off) and my oil pump at the half open mark making it impossible to set the pump correctly.
The pump was my main reason for the inspection as my bike smokes real bad and wet oil comes from the muffler when engine is turned off.
My valves do ssst ssst when ignition is turned on but again they never close and neither does my pump.
I will now look at the Zeeltronic as it sounds like I should fit one anyway.
Really appreciate your reply.
PostPosted: Wed May 16, 2018 7:27 am
As Martin said, the important thing to notice is if the engine runs or not.
What you describe is correct if the engine doesn't run but not when it is started ( valves should close ).
And you have two ways to stop the engine : with ignition switch or with kill switch.
If you turn off the ignition switch, then you have no more alimentation for the power valves and so they can't move any further.
If you turn off the kill switch, power valves are still powered and they should move from closed position ( when engine is at idle speed ) to the opened position ( when engine is stopped ).
PostPosted: Fri May 18, 2018 3:10 pm
Many thanks for the reply,
As my valves stay open (when ignition is turned off) would you put this down to the PV Controller, or is there something else that could be causing the fault.
I have ruled out the servo motor as this checks out ok.
PostPosted: Fri May 18, 2018 6:50 pm
To be clear, what do you mean by "ignition is turned off" ?
*) Engine is stopped and you turn off the ignition key ?
*) Engine is running and you turn off the ignition key ?
*) Engine is running and you turn off the kill switch ?
So my question is again : what happens when the engine is started and running at idle speed ?
