It is currently Fri Sep 21, 2018 1:29 am
Post new topic Reply to topic  [ 2 posts ]
 Post subject: Top Tip for over-use of red Loctite....
PostPosted: Fri Sep 07, 2018 2:53 pm
Tried to remove my front discs today and even with care, most of the bolts wouldn’t budge and the hex’s rounded out. So, welded M10 nuts onto to the bolts, and the heat destroys the Loctite (needs 150+ degrees C). Worked a treat. Hope this helps someone in the same predicament. :smile:
RD400F, with Dave Freist (RIP) carb mods
TDR250 special, carbon, lighter, faster!
Harley Wide Glide, 103 cubes of torque
YZR500 Replica, Latest passion. A money pit!!! A keeper!
Latest purchase, RD500 in Marlboro colours! A project....
 Post subject: Re: Top Tip for over-use of red Loctite....
PostPosted: Fri Sep 07, 2018 3:47 pm
A good solution for an awful problem. Well done.
Good tip... think carefully before using red Loctite on anything you need to take apart again, especially if the fastener is small and fiddly to start with.
