Rear Cylinders
Rear Cylinders
Curious as to why is there a lack of rear cylinders for sale on ebay and other forums? (Seems to plenty of the lower front pair about.)
Are they more prone to failure due to seizing / overheating and therefore are trashed more often?
What should I watch for if they are prone to failure?
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Yamaha AS3 125cc 1978
Yamaha AS1 125cc 1979
Honda CX500
Honda MT125cc 1980
Yamaha TZ125G 1981-82
Zeger TC500cc 1983-84
Yamaha RD500LC 1985-87
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
- Speed Freak
Re: Rear Cylinders
Yes, often the upper left seems to be an issue.
Good that rear left and right are the same.
One theory is that it is the first one which doesn't get fuel when the tank is empty because it's the closest to the fuel tap. Then this one runs lean.
Other theory is bad cooling of the rear cylinders.
I'm planning to do a CFD simulation as soon as I have the complete engine in CAD.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Re: Rear Cylinders
Thanks the reply
Didn't know the rears were the same
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Rear Cylinders
My cylinders are over with Bill Wilson getting rebored as we speak, Top bloody cylinders ran lean or overheated up in the mountains and lost a piston, Bottom two are still like new, Had to bore them all out to the last bore to get the damage out......
Its a problem with them...
Re: Rear Cylinders
And then there is the issue with the rear timing being off by 2 or 3 degrees causing them to run hot.
Re: Rear Cylinders
Exactly, I picked up a degreed woodruff key on here to help put it back in line, Ill take timing measurements and see how much it is out before I fit the key..silverstrom wrote: ↑Fri Nov 15, 2019 4:17 pm And then there is the issue with the rear timing being off by 2 or 3 degrees causing them to run hot.
Re: Rear Cylinders
I bought 2 of them to correct the 2.5 degree retarded rear timing.
I have read here that if you use 4 TZR (2MA/1KT) pistons this is no longer an issue as the rear pistons are no longer offset on the pins.
Re: Rear Cylinders
I am using tzr pistons on my build and I have an off-set key as well.
I'm planning to start the rz500 engine build during thanksgiving, will keep you all posted
Re: Rear Cylinders
Bill is fitting Wiseco pistons as the cylinders are pretty well ported, 34mm carbs etc.
Re: Rear Cylinders
Please do. I am interested in how the rear timing measures with the TZR pistons before the offest crank key is used.motosapien wrote: ↑Fri Nov 15, 2019 6:22 pm I am using tzr pistons on my build and I have an off-set key as well.
Re: Rear Cylinders
You will see a difference of 0,5 degree before and after by changing the pistons.
The original pistons pins have an offset of 0,5 mm toward the exhaust.
The corresponding new TDC will be at X where sin(X)*50 = 0,5 for a stroke of 50 mm and an offset of 0,5 mm.
This offset of the piston pin is not the main reason of the offset between the cranks.
Re: Rear Cylinders
I had the bike new in 1985/87 and can't recall overheating issues or Yamaha doing a recall to fix the issue. So is it something users are doing with mods to the engine tune that are causing the issue?
Yamaha FS1E 1975
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Yamaha RD200 1976
Yamaha RD400 1977
Honda CX500
Honda MT125cc 1980
Honda C90 1989
Yamaha DT175 1993
Yamaha RZV500R 2018
Re: Rear Cylinders
The rear cylinder happens stock bikes also, I had 3 of mine blow up back in the day and they were stock, Rode hard on the country roads of Ireland
Re: Rear Cylinders
I think the biggest difference between then and now is pump fuel quality.ChequeredFlagRacing wrote: ↑Sat Nov 16, 2019 11:32 am I had the bike new in 1985/87 and can't recall overheating issues or Yamaha doing a recall to fix the issue. So is it something users are doing with mods to the engine tune that are causing the issue?
Has anyone heard of a burned up rear piston on a properly tuned bike running race fuel?
Re: Rear Cylinders
I remember i did use different jetting for the rear barrels
