Footpegs
Re: Footpegs
You can sometimes get rivets for some bikes, but the question then becomes how do you mash the heads to the right shape and tension. One some bikes ive drilled/ground down the heads and then fitted either allen headed bolts (socket screws) with dome nuts red loctite'd on, or fitted longer stainless pins (sometimes called cotter pins) with an R clip or split pin.
www.2smoked.com
82 RD250LC '251LC' YPVS
Re: Footpegs
I literally just did this. I had an old rusty corroded set of 500 pegs and I ground the heads off. Got them powder coated and refitted using Cotter pins and R clips. Just as Jon said. They look great
Re: Footpegs
I got the pins in the local hardware store and cut them back to size..
Re: Footpegs
Tacky1 they look great!
Re: Footpegs
All the better if you can find stainless ones, I got different sizes on ebay, in 5mm increments.
www.2smoked.com
Re: Footpegs
Look up these Suzuki part numbers for your footpeg solution -
09208-08020 Pin, footpeg
https://www.partzilla.com/search?q=0920 ... =typeahead
08332-1106A Clip, footpeg pin
https://www.partzilla.com/search?q=0833 ... =typeahead
I found these to be a really clean solution and readily available. I used a stainless washer under the clip to get the correct freeplay and isolate the clip from the footpeg bracket.
Re: Footpegs
Nice solution!
www.2smoked.com
Re: Footpegs
I like the stainless pins from the Suzuki. Very clean. I’ll just have to order some
