Hi, Help please.
All 3 locks use the same key, but the ignition lock is worn, and even with a newly cut key, the key can be removed in the ‘on’ position.
What is the best way to fix? Strip existing barrel and replace ‘tumblers’ or buy another lock and swap/modify tumblers?
Thanks guys.
Ignition Lock Over-haul
