So what are guys doing if they want to start with new coils on a 1985 47x model RD/RZ500? Where to source?
TIA
D
Coils? Where to Obtain?
Re: Coils? Where to Obtain?
i have just bought a set from zeeltronic they work perfect, also one of their ecu/s much better than standard ones, have also used dyna coils but more expensive
Interesting. Thanks. What did the coils and the ECU end up costing you?
i think the coils were about £40 each, the ecu £220 plus you will have to pay import duties but well worth changing to this system, far better than standard once set up it will start and run much better, i am running these on both my bikes
If you want to read something about the Zeeltronic ignition, check out the electronics chapter of my tuning manual:
https://www.rd350lc.de/downloads/MK-Dok ... Seiten.pdf
Thanks Martin! Great resource.
