Oil check v/v’s
Sub forum for RG400/RG500 owners and enthusiasts
PhilTurner
Oil check v/v’s
#1 Post by PhilTurner » Thu Mar 31, 2022 5:21 am
Recently bought an rg500.Have done a lot of work on it to get it to look o.k.Whilst the engine runs well I have the problem of two stroke oil seeping out of the 2 left carbs when standing.
Doesn’t, appear to come out of the two right hand carbs(probably the shortest route to the left carbs)
I am looking at putting the oil check v/v,s that are for the Yamaha rd500 on the outlets of the pump before it enters the carbs.Is this the best option and has anyone used clear lines for the oil supply assuming they are the same internal dia as the Yam ones and compatible.
The earlier thread didn’t give a definite solution.
Any advice will be greatly appreciated.
P.s will post some pictures if anyone is interested. Thanks Phil Turner
kpke
Re: Oil check v/v’s
#2 Post by kpke » Thu Mar 31, 2022 9:50 am
Congratulations. Pictures or it didn't happen :smt002
I think there was a recent thread on here about using the Yamaha check valves on the RG.
tacky1 I believe has done this.
tacky1
Re: Oil check v/v’s
#3 Post by tacky1 » Thu Mar 31, 2022 10:42 am
Yep, I used these on both my RG500s, No probs and stopped the carb leaks on both.
https://www.partzilla.com/search?q=8CH- ... =typeahead
PhilTurner
Re: Oil check v/v’s
#4 Post by PhilTurner » Thu Mar 31, 2022 2:02 pm
Thanks for the quick replies,will get the check v/v,s and fit them and let you know the outcome. Thanks Phil.
thumper580
Re: Oil check v/v’s
#5 Post by thumper580 » Mon Jun 26, 2023 9:27 am
Older thread but wanted to ask...
Adding the inline check valves, it's OK to use them with the existing check valves in the carbs?
tacky1
Re: Oil check v/v’s
#6 Post by tacky1 » Mon Jun 26, 2023 8:04 pm
thumper580 wrote: Mon Jun 26, 2023 9:27 am Older thread but wanted to ask...
Yes, Both mine have the OEM check valves and inline valves and zero probs,
