Hi Everyone
Trying to find out if a R6 2CO rear wheel 5.5 width will
Go into the standard RD500 swingarm.
Anyone Managed this?
Ade
Yamaha R6 rear wheel in RD500 swingarm
Re: Yamaha R6 rear wheel in RD500 swingarm
Check with member kpke, he’s done the R6 wheels, not sure what year though.
Done the Yamaha YZF600 17" conversion in the stock swinging arm. Pretty easy, I think the R6 is more tricky from memory when I was researching
Bikes:
RZV500R FZR1000 forks wheels JL pipes
RD350LC N2
RD350LC N2
YZF yes but the R^ will be too wide i would think.
Yes you are right that was the issue when I looked into it the YZF600 wheel is not quite as wide and does only just fit so anything bigger in stock swinging arm will require a large hammer!
Bikes:
RD350LC N2
RD350LC N2
